DaveOmak
Dusty, Here's some pictures of my solution to plowing snow on gravel.
The idea was born from having to re-gravel my drive my first spring here.
I set the initial height of the blade to 1/4" or so using the wear bolts.
After that, the blade height is adjustable by lengthening or shortening the top link. Whether in reverse or foreward you will need to readjust the top link for the direction you are going. Set the blade "HIGH" until the ground freezes and sets the gravel. Then you can lower the blade to skim the ice.
I had my local machine shop bend new 3/8 shoes after I wore out 1/8 shoes in 2 winters. The shoes really help for leveling dirt, gravel etc.
The shoes attach using the wear plate bolt. The piece of flat bar welded to the back of the blade helps from tearing the shoes off when hitting something that wont move. The shoes are turned up on both ends for pushing or pulling.
I put wings on the blade to keep the snow from sliding off the blade. Really helps a lot.
Hope that gives you some ideas to work with. Dave
