How to wire a Bobcat stump grinder SG60 to work on an ASV Rc100???
   / How to wire a Bobcat stump grinder SG60 to work on an ASV Rc100???
Thanks everyone for your help. I think today finally after a couple weeks of time and research I figured it out. Thanks Dennis from Wisconsin was the guy with the knowledge! Bobcat makes an adaptor that goes from the attachment and converts to a 14 pin connector. For my Stump grinder the SG60 it's part number 6725383 $292.83 and for the snow blower (not sure which model) it's part number 6728165 $194.77. And then you plug the 14 pin adaptor into another adapter that will plug into the Cat Asv 8 pin plug. It's part number 714648 $230. So I thought I would post it up and the next one of you that needs the info won't have to waste all the time I did trying to figure it out. My local Bobcat dealer was clueless. Bobcat of Green Bay knows their stuff! Merry Christmas!
   / How to wire a Bobcat stump grinder SG60 to work on an ASV Rc100??? #12
Good to here there is a "proper" way to do this. Hope it works well for you.
Ken
I wanted to follow up on this thread, I couldn't find it the last time I looked.
The wiring harness I bought all plugged in, but did not work. Evidently the CAT machines have a secondary switch on the controllers, which I thought I had, but it was a horn button.
I believe these adaptors would work on a Cat machine, but not the ASV.
I ended up wiring my harness directly to the solenoid switches on the stump grinder and it worked. I had to add one additional switch for the 3rd cylinder.
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
New Holland 650 Hay Baler (A53317)
New Holland 650...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
15200 (A56857)
15200 (A56857)
