Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,331
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
You must be lucky I used to have a titan but the it's mpg was terrible, I was very happy to trade it for a diesel. My titan had the optional 3.36 rears with the 5 speed auto. Nissan never put a 6 speed auto into the titan or 4.10's. The only rear ratios available are 2.94 and 3.36, and the factory locker only works in low range. However in 2011, you will be able to get a titan with a 6 speed but it will be powered by a hemi since it's going to be a rebadged dodge.
Now the titan I owned ran great and got average MPG till they started the ethanol blend, after that it was terrible.
Yes, you are right, the tranny is a 5 speed with OD. I hit the wrong key typing. My fault. My truck is a little different. My dealer does mods. My truck has a 2" dealer installed lift, dealer installed 33" Off Road Tires, and a locker that will work in 2 wheel drive, not just in 4 low like the factory one is set up. I have a second locker switch down by my left knee to engage the locker in any gear (2 wheel drive, 4 high, or 4 low). The switch you can see in picture #2. Its on the far outside down next to the pedal adjust switch and the cargo light switch. I still have the switch down by the center shift for normal locker use.
I will have to check on the 4.10's but I am pretty sure that is what it has. I know it has Dana axles and I have the big mirrors and big tow package of 9,500# or 9,300#, I cant remember. I know it tows great.
Chris
