RTV 1100 Turbo
/ RTV 1100 Turbo
Ok time for another update, only with pics! finally got a camera, nice weather, and some time to start on the project. Took me about 5 hours to make the flanges, by hand. They were originally gonna be done CNC mill by a friend, but was too lazy to do it. Oh well always better to do it yourself anyways. There's alot more pics to come, still need to make the gauge pod for the cab an get some pics of the gauges.
There it is as it sits right now. I know the shop is a mess, thats what happens when you have too much sh**.
here you can see the oil feed line that i plumbed up using brake line. It T's off of the oil pressure sensor port. That way if something was to happen to oil pressure or turbo, i'll know about it. This was a real pain to install, not alot of room to move a wrench. I used brake line because it blends in with the engine and is more durable.
The lil turbo I picked up brand new for $220.
just a pic of the flanges i made, with studs, not bolts. not done yet.
Heres where the turbo will be mounted, well, the round-abouts area haha.
ok, not real sure which one i want to use yet. the one on the left is off a New Holland back hoe, the one on the right is off a CAT D4 dozer. the backhoe one is 2.5in dia, the D4 is 3in dia. Im thinkin the smaller one, the curved elbow matches the curved lines of the RTV more. Opinions anyone?
Intercooler and fan, got both for $20 each. Intercooler is off an Eagle Talon, perfect size! Still more pics i need to take. Putting a Snorkle on that will feed both the intake and intercooler cool fresh air. Custom gauge pod with some neat gauges. Stay tuned for more updates as i get underway!
/ RTV 1100 Turbo #23
Looking good so far, hope to see more updates soon. :)
/ RTV 1100 Turbo #24
I have turbocharged several small kubota and Yanmar diesels with excellent results. I added a turbo to a Grasshopper 721D mower over 5 years ago, taking it from 21hp stock to an estimated 30-32 hp at 5 psi boost. It has had over 1000 hours of use since at max power with no issues. I have also turbocharged a John Deere 2025 utility tractor and a Deere Gator HPX. I personally see no reliability issues if you increase the power within reason. I attached a picture of the gator with a turbo.
/ RTV 1100 Turbo #25
Ummmm................ yeah, we will need more pictures from you also ! :)
/ RTV 1100 Turbo #26
Any more updates? Looks like a neat project. I know my 1100 could use more power.
/ RTV 1100 Turbo
Its been awhile since i've been on here an gave you guys an update on the project. I dont have any pics, but I did get the project finished. However, the turbo I picked ended up being too big, it would only achieve 1.5psi of boost, no noticable difference at all. It sounded just like a Dodge ram diesel truck with no muffler. had that really cool whistle. I ran into a problem sealing the return line off the turbo. It would leak, an mixed with the air coming in from under the vehicle, covered the whole back of it with motor oil. As of right now its off and version 2 is in parts gathering stage. Hopefully this winter i'll have some time to start messing with it again. It appears to me that what really holds these machines back is the transmission, it just robs too much power. thanks for all the replies!
/ RTV 1100 Turbo #28
I agree, it appears on all RTV's that the tranny hogs up a bunch of power. I noticed this on the RTV500. The 500cc engine makes plenty of power, just seems that it's being held back by the tranny.....CVT's move the flywheel power directly to the wheels ..HST's really don't.
/ RTV 1100 Turbo
If these RTV's had the equivalent of the Gator's or polaris' transmissions, it'd be one **** of a machine. I think the gators tranny requires more maintenance than the hst, but i could be wrong. my only real complaint about the RTV is that there isnt much top end speed, other than that i love everything about it. Power is good, i just think every diesel motor should have a turbo, and when is having too much power a bad thing haha
/ RTV 1100 Turbo #30
Agreed....Love my 1100, but it could do better.
/ RTV 1100 Turbo #31
joeshmoe_44883
Did you try running with no air filter and or intake piping?
Just thinking that if the intake system was restrictive, an engine which is often called an air pump because it hauls air in and pushes it back out, this would have a large effect on the output. Meaning less air in, less air out.
Just a test that might explain why the low 1.5psi.
Be extra careful if you do try this test as the intake will digest anything close to it. And that can lead to one sick engine.
/ RTV 1100 Turbo #32
I bought the complete kit, turbo and all, a year or so ago for my RTV1100. I'd say the entire installation took me less than 2 hours; and that was taking my time and making sure I did everything exact per the instructions.
I'm completely happy with the results. I didn't expect to pick up any top end speed and I didn't. Well, maybe a couple mph, but I attribute that to the engine simply not being able to hold the speed before. I was one of the first to get an RTV1100 and I bet it didn't get 15 hours on it in the first year. My wife and kids simply hated it due to the sudden jerk stop when you let off the throttle. The coast valve changed that. Then they didn't know what gear to pick. The turbo changed that. Unless there are steep trails involved or towing something, it's just put it in "H" and away you go. It gets used a lot more now.
I managed to put my Grasshopper mower in the lake again this weekend (not exactly in the lake, but stuck where it would have gone in if I didn't stop). I discovered that the reverse gear in the RTV1100 is geared too high. Turbo and all, locked in 4X4 with differential locked, it would not spin the tires nor pull the Grasshopper out (Grasshopper weighs about 1500 pounds with the front deck I have on it).
I could use the winch to pull it out or turn around and use "L" and it would pull it out, however, trying to just pull in reverse just resulted in grunt and some exhaust smoke.
/ RTV 1100 Turbo #33
I wonder if you still need to adjust on the servo screw that Matt had talked about in previous posts. I've backed mine out about 2 turns, but will be experimenting more to find the sweet spot. At one point I went too far out and lost ground. Each machine he said is different so yours may need more or less adjusting.
/ RTV 1100 Turbo #34
I had the guy who rebuilds all of those hydro drives in this area for a living do all the adjustments for me on a weekend. He spent 2 weeks at the Kubota plant in GA learning all about the drive systems and can build them in his sleep. He laughed at me when I asked about backing off the throttle to let the 2nd pump kick in. All the talk on this board about another pump is all a crock. There is no such thing. You're simply trying to back off the hydro pulling enough to get engine RPMs up. He laughed and laughed at me asking about that special 2nd pump!
As I mentioned somewhere else here, my RTV1100 will spin both back tires on concrete for about 5-6' with the rear diff locked taking off. I think it's adjusted about as good as it's going to get. I think they just put too tall of a reverse gear in them. He made up a deal out of different parts where you can control the engine RPM by hand just like in a tractor for some guys who do a lot of heavier trail riding. From what I'm told, if you have a turbo and the engine RPM's up to the rated max and then feather the hydro pedal it will turn the tires in reverse. I don't really need it that bad. At that point the driving and pulling power would be pretty well the same as a 30 hp Kubota tractor. I don't know what such a tractor would weigh, but I know Kubota has a nice advantage in not being too heavy in the SCUT sized tractors. Clearly I'm a person who would not be happy at all with a 20 hp SCUT that weighed 3000 pounds!
/ RTV 1100 Turbo #36
If you look at this site, it is actually called an "assist motor".
kubota RTV
I think that is where the confusion comes from; there is no plumbing from the engine (only power source) to any additional motor to provide power. Usually in hydraulic circuits, an assist motor is a fancy name for a setup that prevents the hydraulic motor from losing prime and cavitating. I think the misconception is that it is a separate motor with separate plumbing that provides additional power; which it isn't. If you notice, the foot on the throttle never lets off in order to get the "assist motor" to activate. It looks more like what a throttle plate would be on an older Cummins engine. You could get all sorts of different angles on the throttle plates that would have different affects on how the truck would react to throttle positions. The "assist motor" seems to only direct more flow to the high pressure cut off valve rather than act as any sort of 'motor'. I would call it more of a valve, but doing so probably wouldn't help sell more RTVs.
/ RTV 1100 Turbo #37
Dargo,
Do you have the part number for the oil return line fitting you used to plumb your turbo?
/ RTV 1100 Turbo #40
Dargo,
Not off hand. The supply is a braided stainless covered line but I believe the return is just a rubber line; I think. The engine seems already plumbed for a turbo. When I bought the kit, installation was a breeze. Most time was spent adjusting the hydro drive. I can look, but I can't say for sure if I recall seeing any part number on that line.
Adams Tender Trailer (A61306)
Adams Tender...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2007 GENIE Z60/34 TELESCOPIC BOOM LIFT (A60429)
2007 GENIE Z60/34...
