MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,222
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
You need a car battery, a car horn, a relay that operates on 12V, a magnetic switch for the door(it will have Normally Open and Normally Closed contacts inside), some wire large enough to handle the horn current, some smaller wire, a couple small battery clamps and an on-off keyed switch for outdoor use.
Mount the horn above the door, under the eves pointing straight down at the door. Run the heavy current wire into the building.
Run a high current wire from the positive battery terminal clamp to the A side of the high current relay.
Run a high current wire from the B side of the high current relay to the positive horn lead.
Run a high current wire from the negative(ground) of the horn back to the negative battery terminal clamp.
The horn is wired. Now you need to wire the coil of the relay.
Mount the magnetic switch on the inside door frame.
Mount the key switch through the wall.
Run a small wire from the positive battery terminal clamp to the A side of the key switch.
Run a small wire from the B side of the key switch to the A side of the normally open contact on the magnetic switch.
Run a small wire from the B side of the normally open contact to the A side of the coil on the relay.
Run a small wire from the B side of the coil on the relay to the negative battery terminal clamp.
Clamp the clamps on the battery. Arm the switch. If someone opens the door, the horn goes off. Chances are they will leave the door open and run, which will leave the horn on until the door is closed or you turn off the switch. Pretty simple, but the horn will stop if the door is closed. So you may want to make a latching circuit that will keep the horn sounding even if they close the door. The only way to silence the horn will be to turn off the switch, or remove the battery clamps. I will have to find my circuit for that. There are a few ways to accomplish it. One is to use two relays. The first one triggers and holds the second one on. The other way is to use an SCR (silicon controlled rectifier). It is a simple circuit that is easy to build. I built many of them for our company security system. If someone opened a door it would latch an alarm on and the watchman would have to go to the door and turn a key switch to silence it, forcing him to observe the situation in person. I will try to find it.
