At Home In The Woods
   / At Home In The Woods
Obed,
What are you finishing the floors with?
Getting your concrete guy to fix it is cheap right now, because it's his mess up.
Half the basement will be concrete floors (garage, utility room). The other half will eventually be carpet and vinyl. In the grand scheme of things, I'm not sure I would notice these spots if water weren't sitting on the concrete to show every dimple.
Are the size of the puddles abnormal? How can a concrete guy fill in a low spot without the patch up work chipping later?
Obed
   / At Home In The Woods #292
The water shows you were the low spots are. Measuring how deep they are will tell you if you need to do anything or not.
For a concrete finish, I don't know if self leveling compound will work. It's always quite a bit darker when I use it, and I've never seen what it looks like over a period of time. It dries so quickly that you can tile over it the next day.
I don't have any experience with staining concrete other then talking to the guys after it's done. Prep and the condition of the slab are important, but from what I understand, they will stain anything. There is ideal, and then there is what they have to work with. If you put a clear coat on it to make it shiny, you will see more imprefections then if you leave it dull.
I personally don't care for concrete floors. I tried them, and some of my clients have them. In my opinion, it's a fad that is popular right now, but like allot of things that people feel they must have in a house, it goes out of fashion after awhile. I've tiled over most of my concrete and plan to cover the rest with wood next year. Some things are timeless, others are gambles on how long they will look good, or something that you want.
Eddie
   / At Home In The Woods #293
Eddie
Here in the Seattle area, basements, daylight and otherwise, have had concrete floors for over 80 years and they are still doing it. I don't recall ever seeing one that wasn't.
   / At Home In The Woods #294
I'm not sure if you're pulling my leg or if you misunderstood my post.
Concrete floors with a colored stain, or many colors of stain have become a very popular trend in everything from high end homes to Walmart. I call it a trend because I'm unsure of how long it will remain popular. My guess is that in ten years, it will not be done anymore, but that's just my opinion.
If I wasn't clear, I apologize.
Eddie
   / At Home In The Woods #295
razvy,
I'm very impressed with your project. Thanks for posting the pictures. Did you build the forms for the poured walls yourself?
Obed
O yes , I use 4'x8'x3/4" plywood coated whit used motor oil which I used later for sheeting the floor, my walls are 10" thick and 4 ' high.
I like your concrete job, come out perfect , at mine I have lots of flows that's the price you pay when you work by yourself :rolleyes:
   / At Home In The Woods #296
Obed
I would put a good commercial grade tile in the laundry area. It's soo much easier to clean and keep looking nice than concrete.
Leveling your dips for tiling shouldn't be any issue from the way the pics look at least. There are three leveling methods, the tiler can use leveling compound and a latex bonding agent, or for deeper spots there are mortars for leveling/building up low areas. For the most part, tilers will trowel thinset mortar ahead of the days work area with a 2-3 foot long trowel to even out any dips. That works just fine as long as you don't exceed the thinset mortars max depth recommendations, and I'm not sure that really matters for a small spot either.
The garage floor could be fine with just a good sealer applied periodically unless you like a finished garage look. If you like painted concrete which does keep it from getting stained by oils, etc., paint it after it has cured out but before you get it dirty. :D
Dave.
   / At Home In The Woods #297
Looking at the second picture in post 287, I also noticed that there are no headers above the exterior window and door. Is that a load bearing wall? I keep thinking that it must be, since it's an exterior wall. Even if the floor joists line up on that wall, and spread the load out that way, it's curious that they didnt' put a header in there anyway.
Eddie
   / At Home In The Woods #298
Eddie
I agree that some things are timeless. The trick is to choose things that fall in that category. One example I think would be granite/marble/slate countertops. I can't imagine anyone preferring formica over those - ever. Another timeless material IMO would be real hardwood flooring. The laminates and composites will never take on the aged patina of real wood. They won't last nearly as long either.
Etched and stained concrete could easily be over done I think. It may be a nice accent to an area that gets plenty of natural light. I wouldn't go into the ornate patterns too much. In any case, if it gets old, it can be tiled over or area rugs can obscure it, make it less prominent.
I am no interior designer for sure. It's hard to pick the next Harvest Gold or Avocado appliance colors. :D I think stainless steel is very faddy now and people will get tired of it in the future. It's a cold and maybe overly commercial type finish. I'm thinking white appliances are ready for a come back.
I have noticed that most new homes tend to follow current fashions very closely. That makes sense for a builder who wants to sell it, since it will be appealing to the largest number of people and represents little or no risk taking on taste. The end result is a lot of houses with no differentiating characteristics. That can be boring and souless. Twenty years from now, these houses will be as easy to pick out as a 1960's house is today.
When building your own home, one you plan to live in long-term, and as long as it isn't carried to an extreme, I think it's nice to go with what you find pleasing and to your personal taste.
Dave.
   / At Home In The Woods #299
The nice thing about getting tips or ideas is that sometimes one or two just click and you use them. Our basement is just a basement with my workbench and a workout area. I painted all the concrete walls with a regular white house paint to brighten it up and used regular porch and floor enamel on the floors to keep it cleaner and hold down the dust. That and I used 4' flourescent lighting to make it even brighter and not seem like a basement. Cheap idea for parts of the basement not used for living. The wall and floor paints held up great for 15+ years in our last house.
   / At Home In The Woods #300
Dave, I read from this: Your wife wants stainless steel, you have white that works just fine. That is my exactly my case.
Lone Star dump trailer (A55973)
Lone Star dump...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58216)
2008 MOTIV...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
ALLMETAL MOBILE PRESSURE WASHER (A58216)
ALLMETAL MOBILE...
