No-till drill opinions.........
   / No-till drill opinions......... #1
Georgia_Cattleman
Georgia
Hello, first time poster here who was referred to this site by a friend who reads it regularly.
I'm looking for opinions on no-till drills. I'm a cattleman and the drill will primarily be used for pasture seeding, establishing winter grazing, and planting silage crops (round bale silage - millet, sorghum). There are two primary options right now, Great Plains and Haybuster.
I'm looking at the 1006NT Great Plains and the 107 Haybuster. Prices are both right at $22,500, and both dealers (Great Plains thru the Deere dealer, Haybuster thru the Ferguson) are about the same distance from the homeplace and offer good service and support. I have an established relationship with both (Deere tractors, Krone baler from the Ferguson place) and would feel comfortable buying from either.
I've been renting a no-till drill, a TYE, and it's a solid drill but my operation has grown to the point where I can't wait around when the drill is out to another customer, and I like the TYE, but there isn't a local dealer.
Any experiences with either of these drills?
   / No-till drill opinions......... #2
Most Haybuster dealers sell their rental drills in like new condition and you can save $$$ thousands.
   / No-till drill opinions......... #3
Here is my vote.:cool:
attachment.php
   / No-till drill opinions......... #4
Great Plains is a great drill. The advantage the Haybuster has is their 107 10' drill has the tires on the inside and you can legally pull it down the road. A 1006NT Great Plains Drill is 12'7" wide and is a bit wide for the roads here in the east.
   / No-till drill opinions......... #5
You have width laws for farm equipment?
Yours?
What are your soil types and primary crops planted with the drill? Any issues? How heavy does the drill pull? How is your drill configured - fertilizer, native grass options, etc. (I wasn't paying that close of attention when the salesman was talking about the native grass box, I'll admit I was already mentally figuring depreciation and returns)?
Per several folks I've spoken with the Haybuster pulls a little bit lighter than the Great Plains (seen them doing road crew work being pulled with 4630 NH tractors - 55 hp I think) and are easier to transport.
I'm more concerned with seed penetration as some of my soils are pretty hard (Georgia clay).
   / No-till drill opinions......... #8
I've used both, my vote would be for the Great Plains. But the Haybuster is a very good drill as well. I doubt you will have trouble getting penetration with either machine. Maybe it comes down to your local dealer support?
   / No-till drill opinions......... #9
Yes
We have a clay soil but probably not as heavy as yours.
The drill has worked perfectly. It has grass boxes.
We plant alfalfa/grass and oats, soybeans and winter rye or tritical.
The oats and beans are typically planted in tilled ground and the winter rye is no tilled into existing hay stands or into ground that has been V ripped after taking corn silage.
We pull it with a JD 7210 or 7220 and they just play with this drill.
The drill really couldn't work any better as far as I am concerned.
Here is few action shots from April.
attachment.php
attachment.php
attachment.php
attachment.php
   / No-till drill opinions......... #10
It is like this if someone claims against you, the judge asks how wide was your load. If you are 6" over 10' you will lose because then you have to prove you had an escort with rotating lights, wide load signage, & slow moving vehicle signs in place. If you have more than 4 autos behind you, you are required to pull over and let the traffic go by or you can be ticketed. 2 problems with that is there are not many places to pull off and you are only doing 15-20 MPH being pulled by a tractor so it takes time to even get to pull off spot. Too many tree huggers wanting to control farmers practices.
   / No-till drill opinions......... #11
Our first no-till drill was a Haybuster 10'. It was used on a lot of acres drilling anything that could be run through it. If you are seeding crops to chop on ground that has had previous crop chopped off, penetration will be tough. A John Deere would be best bet if soils are hard from all of the traffic in this case. If ground is not to hard, the GP or HB will be fine. Unless HB has changed there feed system, I like the JD or GP feed system better. Around here you mostly see JD or GP. You might also check into using a Aerway aerator for no-till and pasture ground for loosening top compaction. Excellent tool to aerate and get water to absorb. We really like ours and ground drills nice behind it.
   / No-till drill opinions......... #12
It is like this if someone claims against you, the judge asks how wide was you load. If you are 6" over 10' you will lose because then you have to prove you had an escort with rotating lights, wide load signage, & slow moving vehicle signs. If you have more than 4 autos behind you, you are required to pull over and let the traffic go by or you can be ticketed. 2 problems with that is there are no many places to pull off and you are only doing 15-20 MPH being pulled by a tractor so it takes time to even get to pulloff spot. Too many tree huggers.
Might be a tree hugger or two in that bunch - but - in my experience it's all those idiots that grew up in the middle of concrete and asphalt and don't have the common sense God gave a goose!! :mad:
I'm late, I'm late, gotta get there, gotta get there... where's my Blackberry, my iPod, my iPhone, my laptop, my portable DVD player, my portable GPS, my color display GPS on the dash.... PLUG-IN-PEOPLE! :eek:
AKfish
   / No-till drill opinions......... #13
Around here width on farm equipment does not matter as long as it has a slow moving sign. The safety course I have taken also train to only pull over if you can fully get off the road, like at an intersection.
   / No-till drill opinions......... #14
AKfish
Traffic is a problem that seem to be getting worse. I not only use blinkers if I have them but also hand signal and I still have people pass me when I'm about to turn left. Or better yet pass me near the crest of a hill, had a few close calls the past few years. A few times I can see traffic coming the other way so I pull into the center of the road to prevent them from passing. Some realize why I did what I did, a few others let me know I'm #1 in there eyes. I even just had a guy pass my truck on a double yellow line when I was about to make a left hand turn onto a side road.
   / No-till drill opinions......... #15
Is your local MF dealer not a tye dealer? Usually ever MF dealer is a TYE dealer, or at least carry the parts. I have a really nice TYE 8ft drill for sale at my store. Its a pull type or 3pt. It has both seed boxes, big and small.
And best of all its over 14,000 less!!! We are in NE Alabama. If you are interested feel free to call us. 256-927-5454.
   / No-till drill opinions......... #16
I work at GP, so consider my brand loyalty. if width is a problem, there is a 3 pt version of the 10' no till(3P1006NT). Also the 1007NT has no end wheels. On the plus side there is an R&D department that is always looking for ways to improve the product.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
