>>> AUTO-DARKENING WELDING HELMET ??<<<
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #51
I have one just like it and its GREAT! I useto be some what a professional welder, (well when the full time guy forgot to come in). Now I dont weld every day but I do some heavy duty welding on equiptment repair and it works great. The welding itself recharges the batteries after the initial charge when its new ( just set it out in the sunlight for a couple of hours and your ready to go). I have very sensitive eyes, I use it for brazing, cutting and just heating metal. Visibility is perfect from light to dark. I would buy another one in a minute if mine got destroyed.
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #52
I had one and it did work well but it just stopped working and I just never got a new one.
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #53
Thanks to the op for this thread. It helped me decide what I wanted for Xmas. Can anybody guess?
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #55
Yep. I burned a few welds with my Miller 130 today and it worked great. It'll take a while to get over old habits, like closing my eyes cause I didn't flip my hood down, and flipping it back up when I'm done welding.
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #56
I have never used a Lincoln hood before.-But I know Lincoln makes good products.-Even after I went with a AD-hood I still had a habit of head flipping.- I had a bad habit and would do that while out in public.:D
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #57
I bought a auto-darkening helmet when i bought a miller 180 mig machine, alone with alot of other stuff, had no problems with it so far, i think it is a miller brand. I paid arond $90.00 for it. but it has been a very good one.
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #58
Guys, I used to sell the AD Hoods. The damage from using a Cheepo hood will not be noticed for several years if ever. It is not something that you will know right away. Most Change from dark to light 3x faster than the speed of light so that part is safe. If your hood bothers your eyes it may be because you need a Cheater Lens to stop eye strain. Or go to a darker shade. The Delay feature is the opposite of what some said on here. The delay means that it stays dark for a couple seconds after you break the arc to let the puddle freeze so you dont have to see that white hot weld. Lastly,, The " Good " Hoods turn dark when the batteries fail or if all is not right to prevent a Flash. When you turn them on They go to shade 3 for the good ones and 4 or 5 for the cheepies. All the hoods out there are approved by our government specs so they all should be relativly safe.
I just registered after reading this post to point out the BS. Auto darkening helmets are nothing but large, single-segment LCD displays attached to a battery or solar panel (sometimes both, a solar cell can be used to complete a circuit so it can sort of function as a light sensor). Same sort of display on a pocket calculator but transparent and with just one segment that on, off, or somewhere in-between. LCDs are slow to switch on and off. Notoriously slow. They also have absolutely nothing to do with the speed of light. Look up "twisted-nematic" display. You will see there is physical molecular twisting going on to achieve the variations in transmitted light.
There are disadvantages to ALL auto-darkening helmets.
*There is a brief period where the AD glass has a current applied to but is still in the process of darkening. This period will be DRASTICALLY more noticeable at lower temperatures, at temperatures below freezing your glass might be stuck on or off until you warm it up again. This is because it is just an LCD. Leave a GPS or Game Boy outside in the cold and watch the screen have trouble transitioning between frames. The molecules are nearly frozen and they are slow to move.
*Solar cells do not respond to all wavelengths of light the same. Whereas ordinary darkened glass blocks out light nearly indiscriminately all the time, the LCD-based auto-darkening glass is dependent on a solar cell (or less often a CdS resistive sensor) to determine when to supply it the current it needs to darken. If you get flashed by a wavelength of light the sensor or solar cell is less sensitive to, it could very well go right through the glass and enter your eyes at nearly full intensity. Arc light is pretty much bright full-spectrum so the solar cell WILL see it but wavelength sensitivity is just another important thing to be aware of.
*An arc intensifying fast enough will probably flash your eyes a bit before the glass darkens. There is an advantage here for the AD option because the LCD is racing the intensifying arc, and the arc does not reach full intensity all at once. If it did, there would be even more arc exposure with these helmets, and more people would start to take notice.
You can test your helmet. Use a camera with a long exposure setting, place it right up against the internal glass, use something to cover the back of the helmet so light cannot get in from there, and open the shutter. Start an arc in front of the glass at a distance you are used to working from (do this a few times for good measure), you can also use a camera flash but then you would need two cameras (using a mirror may not work because you don't know precisely when the shutter will open, it needs to open before the flash begins illuminating). Close the shutter to finish the shot and see what develops. Too much light and you should know it, you can compare it to a ordinary darkened pane at the same shade.
There are safe alternatives to AD helmets, the chin-operated type is probably the most exotic: YouTube - Welding Helmet Comparison Chin operated VS Light Activated That one's a little primitive and needlessly expensive for my liking, an AD lens (as a backup) under the main lens would be more ideal so that if you open your mouth to talk you don't get accidental arc-eye.
--I might add that the "my eyes are worth more than $XX" argument is silly although almost understandable. Anyone would pay more for a more expensive helmet if they knew it would protect their eyes better. Do really know what you're buying? Test your helmet. A high-speed video camera would really end the argument. Try using your helmet in the cold and recheck, there should inevitably be more delay. Even if AD helmets are not unsafe they are at best only CONDITIONALLY SAFE.
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #59
That temperature-sensitive start delay is a good argument for setting an AD helmet out in the sun to warm up, as well as recharge, before every welding session.
   / >>> AUTO-DARKENING WELDING HELMET ??<<< #60
Clearly you haven't been on here long or read many threads. It may be hard for you to comprehend, but there is positively a reasonably large contingent of people on here who would indeed buy the cheaper helmet every single time even if there was proof positive they'd get flashed every time. They'd say something like "Well, I'll just blink when I strike an arc. I can still save money that way." Have you not read the Harbor Freight thread??? Spend a week reading that and then tell me that people here won't buy something if they know a more expensive product will be safer, perform better, last longer and be less expensive in the long run.
1828 (A57192)
1828 (A57192)
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2021 Chevrolet Tahoe SUV (A55853)
2021 Chevrolet...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2005 GMC C8500 16FT. Utility Flatbed Truck (A55852)
2005 GMC C8500...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
