New tractor recomendation
   / New tractor recomendation #11
Ok, I'm ready to my my first tractor. A little about me and what I'm needing. I'm 54, a little overweight (Why am I post this) and don't want to buy something that will be too hard to operate or hook up attachments. I have 28acres in southeast Ga. Three acres in lawn, about 8 to 10 in pastures and the rest is in woods. Have no hills at all, flat as can be. I have no need for a front loader that I realize at this time. Would like to keep the pastures mowed, maybe a belly mower for the yard and would like to be able to bush hog some of the overgrown wooded areas around the pecan trees. We have no snow to deal with. I'm concerned about being able to attach the bush hog, maybe plow ect, as I get older. I've never even been on a tractor before. The choices that I have in the area, seems to be a John Deere, Mahindra and a used Yamnar dealer. I'm not trying to make a living with the tractor. I'm retiring and will be living on my little hobby farm. Any advise and help will be greatly welcome.
Daniel
I have a 2008 Mahindra 5525 (3 cyl diesel, 54 hp engine, 45 hp pto) that I use on my 10-acre spread (flat pasture, 6 acres in oat hay right now).
The 5525 pulling my restored Minneapolis Moline P3-6 grain drill
The 5525 pulling my Massey Ferguson 124 baler
I mow the weeds on my place with the 5525 and a 6-ft Hawkline rotary mower (aka brush hog, bush hog, shredder, slasher).
The 5525 price was $12.7K with rebate. The front end loader (FEL) added another $4.4K and the brush hog was $1150.
For your 3-acre lawn, I'd recommend a zero turn riding mower.
Flusher, thanks for the pics. Do you use the fel much, that can be added later? Theres a Mahindra dealer close, I will go back over to them on my next trip to Ga.
Dan
   / New tractor recomendation #13
With the rates being what they are now days its a good time to buy. Get a FEL. I could not imagine not having one. My first tractor, a Ford 861 did not have one and within a week or two I realized I wanted one. My next tractor, a Jinma 284 had one and now I never use the Ford.
I am not a fan of belly mowers. If you want one of them get a lawn mower. A Bush Hog and a rear finish mower do everything I need. I could not imagine trying to run a Bush Hog with a belly mower hanging low under the tractor.
As for hooking up implements there is no easy way, just easier ways. Pats is a good system but still requires some on and off the machine and wrestling. Only way to hook up something easily is get a helper.
Chris
   / New tractor recomendation #14
Take a good look at both of your local dealers. Look at the 30-40 horse power machines. I would advise that you consider a front end loader. Even if you can not for any reason think of what you would use one for, believe me, once you have one, you will use it all the time. Oh, after you decide that you are going to get a loader, be sure that you get one with a skid steer quick attach bucket. You will understand later. ;) Sit in as many seats as you possible can, get a feel for the tractor and it's control layout. All tractors are not the same, even within the same make, each model size is usually a little different than the other, check them all out. Start out by looking at the John Deere and Mahindra websites. Then go by the dealers and start looking at the tractors, get some brochures, ask the sales guys some questions, see what kind of answers you get and if you like what they tell you.
I'm a Mahindra guy, have 2 of them, both very comfortable for me. Comfort is the biggest issue in my mind, if you are on a tractor all day long, might as well be comfortable. That's not to say that I would want a comfortable tractor with a bunch of problems, but a good reliable machine that fits me good makes me happy.
One last thing, for ease of hooking up implements, the Delta Hitch would be hard to beat, pricey, but very good.
Good luck and have fun with your search.
I just thought of this, spend the 15 bucks and get the Compact tractor buying guide. It's on the Home page here and I think that it really can help out a new to tractor person.
   / New tractor recomendation #15
Dan
Yep, the FEL is indispensible in my case since I move a lot of dirt, sand, gravel, mulch, etc around my place. It's handy for toting 50 lb sacks of seed 6 or 7 at a time when I'm using the grain drill in the hayfield.
You can add the FEL later, but dealers usually give a price break if you get the FEL when you buy the tractor.
   / New tractor recomendation #16
Welcome Daniel:
You're just a little older than me, and I gather you're used to the heat and humidity of the south. However, if it were me, I'd have a cab with AC and heat (I wish I had one). A cab will also keep the bugs and dust at bay.
Even if you think you don't need a loader...GET ONE as it will probably be the most used implement you will own. I know it is for me and many others. Get 4WD too, even if your land is flat as a loader equipped tractor is happier with 4WD.
A hydrostatic (HST) tranny is easy to learn, is easy to be precise when doing loader work. I like manual transmissions in my road vehicles; but don't equate a manual car with a manual tractor.
A Quick-Hitch like Land-Pride's QH-15 makes hooking up implements easy. I've never used Pat's, so I can't comment on it.
I was thinking of getting a belly mower (a.k.a. Mid Mount Mower, MMM) until I saw the price and the hassle in the 2001 Deere video of putting it on and taking it off. If I wanted a MMM, I would look at Deere's drive-on system.
Get the hydraulic outlets and Power Beyond up front when you buy it. It's cheaper that way. I installed mine after a number of years and wish I had done it sooner.
Get at least a hydraulic top-link for your three-point hitch. A hydraulic side-link is on my to do list. Again, this is something I wish I had done years earlier. Hydraulic Top-n-Tilt will make your life easier with implements.
How else can we spend your money? :rolleyes:
   / New tractor recomendation #17
DEFINITELY get a loader. If you're worried about doing things easily, you will find HUNDREDS of uses to make your life simpler with the loader. And we're not exaggerating.
I would buy one big tractor and one little one. One for mowing, and one for everything else. My neighbor says he got a Kubota utility tractor and dedicated Kubota riding mower for the same price as the utility JD he was looking at. Personally that wouldn't sway me from JD but it does give you something to think about.
   / New tractor recomendation #18
I would suggest a Deere 3520 or 3720 with 300CX fel, rear finish mower and a rotary cutter or bushhog. I would suggest a cab also, much more pleasant with the ac and heater, and if you have ever stirred up some yellow jackets while mowing you can see the added benefit with a cab. From there you can add some other implements, such as a boxblade, rear blade and ground engaging tools.
You need to go to Deere dealer and get a good IMatch demonstration to see just how well these things work. I can change rear 3pt implements without leavig the seat. Read up on this on the Deere website and then get a demo. This makes changing implements by yourself very easy.
I agree with some of the other posters to consider a separate lawnmower to use for the yard, if you do then skip the rear finish mower.
   / New tractor recomendation #19
I am also a 1st time buyer living in rural Maine on the side
of a mountain with a steep( 7/12 pitch) driveway , 700 feet long.
I have serveal needs that include accessing firewood on the land that is steep, with gullies and boulders. I also need to plow the driveway where we average 4- 6 feet of snow annually. I want to trench the culverts,
crown the driveway, remove stumps and clear some land for a 1-2 acre
garden. I also want to put a dug well and pond near the house.
I am currently snowblowing the driveway with a 10hp MTD.
If anyone has similar terrain to work on I would appreciate any suggestions.I am on a limited budget.
   / New tractor recomendation #20
Welcome to TBN, your needs may vary with this OP, I suggest you start your own thread.
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
VOLVO SD75B SMOOTH...
Gravely Pro Turn 460 60in. Zero Turn Commercial Mower (A59228)
Gravely Pro Turn...
Batco 35' PTO Driven Belt Auger (A59814)
Batco 35' PTO...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
