Snow Equipment Owning/Operating Grapples make lousey snow plows oh well.
   / Grapples make lousey snow plows oh well. #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I know it is a goofy thead title. But hey I was out in the cold to long today. Neighbor down the road had a few trees damaged in the snow storm we had before Christmas and I went to give him a hand. Here is the tree before starting. This tree is some type of cedar that is about 45 years old.
   / Grapples make lousey snow plows oh well. #2
dex
Now the rest of the story....
must be a grapple in that pic somewheres...and what happened to the damaged tree? Did you help him cut it down? Was the grapple in there to clear a path, or to remove damaged limbs?
It was really cold this morning at about 14º. Its a good thing I do well in the cold I had to tram the tractor about 2 miles before working on this tree removal. There are some pro's and cons to different types of grapples. The Anbo has shorter lower tines that makes you grab and clasp everything. Compared to the say the Markham Grapple that has the longer Lower tines that allow you to slip the tines under and carry. The Anbo does allow you to Back rake with the upper tines and that is very handy and will give you a little extra reach. The upper tines will raise the front of the tractor fully extended which surprised me.
dex
Went ahead and took the tree out and moved it down over the bank to be burned in better weather.
There were 2 tress the same size and he decided to take them both out since we were getting the mess cleaned up without hurting his lawn.
   / Grapples make lousey snow plows oh well. #6
Nice! What type of grapple is that? With a log loader 'excavator with a big log grapple/heal rack instead of a dirt bucket' I grab a tree like that after its lay'n on the ground and use the tree as a "broom" to sweep snow for short distances or push the "tree plow" with the grapple against the heal rack ;) Spose you could talk yer neighbor into keep'n the tree for a snow "pusher" for your tractor:confused::D
You can see in this the second pic why I have my wheels set to their widest. There are not many flat spots in WV. Flat to us is if a box doesn't roll away:D:D. I know I have lousy humor.
Its an Anbo grapple. Never thought of that use for a tree but I could use it to sweep the shop/garage out as well.:D:D Here is shot of the grapple.
Here is the finished brush pile. 2 decent sized yard cedars reduced to this small pile. It was cold but it was a day on the tractor and my wife followed along in the truck to take the pics and help pile up the small pieces of brush(you didn't expect me to get off of the tractor did ya. Hey she might have jumped in the seat while it was unattended:)).
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
1996 LUFKIN 45' X 96' SPRING RIDE EXTENDABLE (A59575)
1996 LUFKIN 45' X...
