Not really. Like you say the wheel with the least traction will spin, however the non spinning wheel is providing about equal thrust as the spinning wheel. Both wheels are driving, but youre only getting 2x the thrust of the one with least traction. Not 1 [or 3] wd.In 2wd your tractor is actually 1wd and the rear wheel with least traction will spin.
In 2wd with the diff lock engaged your tractor is actually 2wd with both rear wheels pulling together.
In 4wd your tractor is actually 2wd and the rear wheel and front wheel with least traction will spin.
In 4wd with diff lock engaged your tractor is actually 3wd with both rear wheels pulling together and the front wheel with least traction will spin.
As GW pointed out, the only exception would be a tractor with a front diff lock mechanism of some sort and it would then have true 4wd. I didn't think any tractors were so equipped, but GW educated me on that a while back!!![]()
larry
Locking hubs allow the hubs to be disconnected from the axle shafts on an axle assembly. This is done in passenger vehicles to allow more efficient operation in 2wd by reducing parasitic drag from spinning the front portion of the drivetrain.
Manual or automatic locking differentials force both wheels on an axle assembly to turn at the same rate to enhance traction.
Limited slip differentials (positraction, trac-lok, M7040, etc) use friction discs or such in the differential to bias some torque to the wheel that is slipping.
The front LSD is one of the things I envy about the bigger M series Kubota guys.
because twice the thrust of the spinning wheel is not as much as the thrust of the spinning wheel added to what you can get from the wheel with good traction if you force it to turn too using the d/l.Whaaat? Then why don't you go anywhere when a wheel is spinning in 2WD? And why do you go somewhere when the diff lock is engaged (or at least two rear wheels spin)?
larry
go here - About.com: http://www.howstuffworks.com/four-wheel-drive.htm and click play on the 4 wheel drive demo. I saw this article a few years ago and it really opened my eyes how 4 wheel drive really works and explains why 4 wheel drive really gets stuck unless it has a locking diff.
