Do you oil your choke tube threads?
   / Do you oil your choke tube threads? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
This seemed like a good mid-winter topic. I finally picked up a turkey gun from my brother, (870 Express) and am getting set up.
   / Do you oil your choke tube threads? #2
Other than the light gun oil that is covering the rest of the gun,,,, no.
   / Do you oil your choke tube threads? #3
I always put choke tube grease on the threads,if not you will regret it later in form of a stuck tube in the barrel.I speak from experience.coobie
   / Do you oil your choke tube threads? #4
Down at the auto parts store, at the counter you can pick up a little packet of anti-seize. Just a little bit will do and they come right out. Another thing is to loosen them up a bit when storing the gun.
   / Do you oil your choke tube threads? #5
I'll second others reply, use grease or anti-seize as it will be there when you get ready to change tubes.
   / Do you oil your choke tube threads? #6
x3 on the anti-seize. That stuff is great and works at almost any temps.
   / Do you oil your choke tube threads? #7
Once you find a Choke and Shell combo you like on a true turkey gun there is no reason to remove it. I havent removed mine in 5 years and dont plan on doing it in the future. I did apply gun oil on intial install.
Now, if that gun needs to shoot dove or something else then anti-seize it.
Layne
   / Do you oil your choke tube threads? #9
Ok, now here's a question along these lines,
I have an 11-87 with a chock tube that is cracked. I lent the gun out and it came back with a crack that runs straight down the choke tube. I broke a wrench trying to get it out.
How in the world do I get that tube out? My sense is that the borrower broke it using a different style wrench that only engaged 2 of the 4 notches in the tube.
   / Do you oil your choke tube threads? #10
Take the bbl off and freeze it, then try. Metal constricts when cold, may work.
If not, then a 'smith can cut the bbl down and re-thread.
2006 Sunnybrook Mobile Scout 5th Wheel Camper (A53117)
2006 Sunnybrook...
1978 Taylor TY-250M Forklift (A53117)
1978 Taylor...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
safety baskets (A53421)
safety baskets...
2007 Mack Granite CT713 Day Cab Truck Tractor (A53117)
2007 Mack Granite...
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
