Do you oil your choke tube threads?
   / Do you oil your choke tube threads? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
This seemed like a good mid-winter topic. I finally picked up a turkey gun from my brother, (870 Express) and am getting set up.
   / Do you oil your choke tube threads? #2
Other than the light gun oil that is covering the rest of the gun,,,, no.
   / Do you oil your choke tube threads? #3
I always put choke tube grease on the threads,if not you will regret it later in form of a stuck tube in the barrel.I speak from experience.coobie
   / Do you oil your choke tube threads? #4
Down at the auto parts store, at the counter you can pick up a little packet of anti-seize. Just a little bit will do and they come right out. Another thing is to loosen them up a bit when storing the gun.
   / Do you oil your choke tube threads? #5
I'll second others reply, use grease or anti-seize as it will be there when you get ready to change tubes.
   / Do you oil your choke tube threads? #6
x3 on the anti-seize. That stuff is great and works at almost any temps.
   / Do you oil your choke tube threads? #7
Once you find a Choke and Shell combo you like on a true turkey gun there is no reason to remove it. I havent removed mine in 5 years and dont plan on doing it in the future. I did apply gun oil on intial install.
Now, if that gun needs to shoot dove or something else then anti-seize it.
Layne
   / Do you oil your choke tube threads? #9
Ok, now here's a question along these lines,
I have an 11-87 with a chock tube that is cracked. I lent the gun out and it came back with a crack that runs straight down the choke tube. I broke a wrench trying to get it out.
How in the world do I get that tube out? My sense is that the borrower broke it using a different style wrench that only engaged 2 of the 4 notches in the tube.
   / Do you oil your choke tube threads? #10
Take the bbl off and freeze it, then try. Metal constricts when cold, may work.
If not, then a 'smith can cut the bbl down and re-thread.
2016 Ford F-250 Reading Service Truck (A51692)
2016 Ford F-250...
2017 Nissan Titan SV Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
