Puma 64 vs. Blizzard??
   / Puma 64 vs. Blizzard?? #1
rut3556
Amherst, NH, USA
Kubota L2250, Kubota TG1860
Hi Guys,
I'm going through the great debate as to which of these snowblowers to go for. I realize each of them has a decent reputation, but I'd like to know if one of them is better than the other, and if so, why? At present, I have a Ford 715 w/ hydraulic chute that's literally rusting away. I've had it for 25 yrs. now, so it doesn't owe me anything. This time, however, I want to get something with 4 impellars vs. three.
Thanks in advance for any advise that may come forward.
===RUT===
   / Puma 64 vs. Blizzard?? #2
I have a Puma 64 10 years now No complaints
I did add hydraulic rotate and chute when I got a new tractor with 2 rear remotes.
   / Puma 64 vs. Blizzard?? #3
I think it's a wash. I'd probably buy on price and local availability (in fact, that what I did). I have a 72" Puma and no complaints.
   / Puma 64 vs. Blizzard?? #4
Sorry to HJ the thread but
Rick I was checking your iron listed and was wondering how it is starting them in the cold? With how cold it is I guess your easiest way would be to use a gas tractor.
Last week I picked up hay from a farmer who had a old unstyled JD B in the barn, he ended up hand starting it for my 5 yr old. It was in the low teens temp wise and it started up quicker than I thought it would.
   / Puma 64 vs. Blizzard?? #5
Hard to call one better then the other, both are good machines. either one you buy will serve you well.
That being said, I'd reccomend the Blizzard because it has a considerably larger fan...the B64 uses a 24" Fan, the Puma 64 only has a 20". Larger fan = throws the snow further.
Another thing is the Blizzard are built heavier duty....for example, Drivechain on the Blizzard is a #60, chain on the Puma is a #50.....Weight of the B64 = 479 lbs, Puma 64 = 382 lbs
I love my B74.
If you cant find a Blizzard, the Frontier (JD) SB1164 is a Blizzard painted green. Kubota also has the same blower except painted orange....Believe it or not, the JD unit is priced VERY Competitively.....
   / Puma 64 vs. Blizzard?? #6
In winter I only use the 4000 (diesel) and 885 (diesel). The Deere and Oliver are toys, and the 841 is "out of service".
The 4000 has thermostart and will start in a pinch down to about 10 deg F if it isn't plugged in.
The 885 has thermostart and a cold start advance on the injector pump and will start unaided to about 0 deg F.
They 4000 has a block heater, the 885 has a lower hose heater and both start immediately at any temperature without thermostart if they have been plugged in for an hour or two. I despise doing 'real' work with gas powered tractors, in fact, I recently repowered the 4000 which left the factory as a gasser. I replace my fuel filters between Halloween and Thanksgiving, and treat my fuel with anti-gel beginning at the same time. It is rare indeed when I have a no start condition, or fuel related issues.
>>Hard to call one better then the other, both are good machines. either one you buy will serve you well.<<
Guess if I were buying a brandy new one I'd probably go for the Blizzard. However, I have a chance to get a slightly used Puma 64 w/ hydraulic chute mechanism (new style) for about $1K less than new price. May have to go for it. ;)
Well, I went for the slightly used Puma 64 after all. It was too good a deal to pass up, and came complete w/ hydraulic chute mechanism. Plus, it matches my Kubota better than the old blue Ford 715 blower I've used for the past 25 years! :)
   / Puma 64 vs. Blizzard?? #9
Looks like someone suffered a little interference between the fan and chute baffle; rocks or something left in driveway :confused: Nice looking unit, all the same. Should use you well
   / Puma 64 vs. Blizzard?? #10
If you don't mind, what did you give for that Puma. They are big bucks out west here in Reno.
Thanks, Ken
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
