Oil & Fuel oil filters for 20HP Nortrac
   / oil filters for 20HP Nortrac #1
Frankm
Erie Pa
Nortrac 204
any one tell me what all oil filters will work on the Nortrac 20HP with the yang dong Y380 , some one told me the Fram 3950 would fit , it dont , the fitting on the tractor is smaller then the hole in the filter , Thanks Frank
   / oil filters for 20HP Nortrac #2
The 3950 has 20x1.5mm threads. So that means you've got 3/4-16 threads on the tractor. And that 3950 is a lot shorter than stock anyway. If you want to stick with FRAM, I suggest you try a PH3600 or DG3600. Alternatively, a WIX 51616 should fit too.
//greg//
ok thanks ill try the Fram 3600 next time .
The Fram 3600 Works Great Fits Great , Thanks ! PS My Tractor is the Nortrac , 20HP , 25 HP Will be the same filter .
   / oil filters for 20HP Nortrac #6
You are INCORRECT on the 25 HP tractor and 28 HP. The Fram PH3950 has 20mmx1.5mm Threads and is 3.66 wide at the o-ring while the Fram PH3600 has 3/4-16 Threads and is only 2.98 at the o-rings. The both have 12 psi bypass.
Chris
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2023 John Deere 6R 155 MFWD Tractor (A53342)
2023 John Deere 6R...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
2011 Western Star Trucks 4900 SA Truck, VIN # 5KJNALDR4BPBA7822 (A51572)
2011 Western Star...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2803 (A50460)
2803 (A50460)
