Oil & Fuel oil filters for 20HP Nortrac
   / oil filters for 20HP Nortrac #1
Frankm
Erie Pa
Nortrac 204
any one tell me what all oil filters will work on the Nortrac 20HP with the yang dong Y380 , some one told me the Fram 3950 would fit , it dont , the fitting on the tractor is smaller then the hole in the filter , Thanks Frank
   / oil filters for 20HP Nortrac #2
The 3950 has 20x1.5mm threads. So that means you've got 3/4-16 threads on the tractor. And that 3950 is a lot shorter than stock anyway. If you want to stick with FRAM, I suggest you try a PH3600 or DG3600. Alternatively, a WIX 51616 should fit too.
//greg//
ok thanks ill try the Fram 3600 next time .
The Fram 3600 Works Great Fits Great , Thanks ! PS My Tractor is the Nortrac , 20HP , 25 HP Will be the same filter .
   / oil filters for 20HP Nortrac #6
You are INCORRECT on the 25 HP tractor and 28 HP. The Fram PH3950 has 20mmx1.5mm Threads and is 3.66 wide at the o-ring while the Fram PH3600 has 3/4-16 Threads and is only 2.98 at the o-rings. The both have 12 psi bypass.
Chris
2013 FORD F150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F150 XL...
2007 Volvo VNL Truck Tractor (A55218)
2007 Volvo VNL...
2019 Isuzu NPR-HD 24ft. Box Truck (A55788)
2019 Isuzu NPR-HD...
Two Pairs of 10ft Fork Extensions (A55787)
Two Pairs of 10ft...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
