Oil & Fuel oil filters for 20HP Nortrac
   / oil filters for 20HP Nortrac #1
Frankm
Erie Pa
Nortrac 204
any one tell me what all oil filters will work on the Nortrac 20HP with the yang dong Y380 , some one told me the Fram 3950 would fit , it dont , the fitting on the tractor is smaller then the hole in the filter , Thanks Frank
   / oil filters for 20HP Nortrac #2
The 3950 has 20x1.5mm threads. So that means you've got 3/4-16 threads on the tractor. And that 3950 is a lot shorter than stock anyway. If you want to stick with FRAM, I suggest you try a PH3600 or DG3600. Alternatively, a WIX 51616 should fit too.
//greg//
ok thanks ill try the Fram 3600 next time .
The Fram 3600 Works Great Fits Great , Thanks ! PS My Tractor is the Nortrac , 20HP , 25 HP Will be the same filter .
   / oil filters for 20HP Nortrac #6
You are INCORRECT on the 25 HP tractor and 28 HP. The Fram PH3950 has 20mmx1.5mm Threads and is 3.66 wide at the o-ring while the Fram PH3600 has 3/4-16 Threads and is only 2.98 at the o-rings. The both have 12 psi bypass.
Chris
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
2009 GMC C5500 Landscape Dump Truck (A55788)
2009 GMC C5500...
2006 FORD F-350 (A55788)
2006 FORD F-350...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
