shear pins
   / shear pins #1
jimbo64
went to tractor supply and one other farm supply store to buy shear pins for my bushog and they both said to use 7/16 or 1/2 number two bolts as shear pins. old pins were shear pins with a grove in them to break under pressure. Will #2 bolts shear as easily- 7/6 or 1/2 inch #2 bolts seem pretty substantial
and i really not interested in tearing anything up=neither store carried "shear pins".
   / shear pins #2
#2 bolts aren't a very strong grade. I broke a shear pin on a bushog, and replaced it with a grade 5 bolt. Broke that bolt so I used a grade 8, and broke it too! The tractor was a tc30 running a 6ft bushog in tall grass and thorns (all it wanted) Still not sure if something was wrong with the bushog or what caused the repeated pin/bolt breakage (not my tractor)
I wouldn't be worried about a grade 2 bolt being too tough to use as a shear pin.
   / shear pins
thanks for the input carpenter383- is half inch to big or should i stay with 7/16
   / shear pins #4
I picked up a 3pt snow blower a week ago. I knew I was going to go through a bunch of shear bolts so I wanted to stock up. My manual made reference to #2 grade bolts
   / shear pins #5
You better buy them by the bagful.. I run only grade 8 bolts and I still break plenty of them.
   / shear pins #6
I would use a 1/2 in bolt if thats what it takes to fit the hole tightly. You don't want to have slop in the holes where the bolt goes through.
E-Z Trail 700 bu Auger Wagon (A59814)
E-Z Trail 700 bu...
JCB Loadall 506B Telehandler (A57453)
JCB Loadall 506B...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
Misc Pallet of Water Pump and Vacuum Cleaner (A57454)
Misc Pallet of...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
