Ford 1700, more power?
   / Ford 1700, more power? #1
90dodgectd
Mount Airy, MD
1982 Ford 1700
Hey guys another newbie here. We have an 1982 Ford 1700 4x4 and I was wondering if there was anything i could do to get alittle more grunt out of the little diesel. Are there any screws i can mess with on the injection pump? Or am i stuck with the 23HP. Id also like to straight pipe it. How does it sound? I dont know why i want to do all this, I just do :thumbsup:.
   / Ford 1700, more power? #2
Can't squeeze more blood out of turnip, aye:D Well, if you have creep then use it. Just go with the lowest speed at the rated 2500 rpm to get all the juices out. In order to get more hp and keeping your rig the same can be done only by turbo charging it. Yet to see any hot rod 1700. What is it that you need to do?
By straight piping it, do you mean taking the exhaust out and put a straight piece of pipe instead?:confused:
JC,
Yeh just replacing the muffler with a straight pipe so its loud and noisy. The only thing we really use the tractor for is bushhoging, the occasional post hole digging, and moving heavy parts around our property. I dont need to do anything to the tractor, I just want to.
   / Ford 1700, more power? #4
Your dealing with something approaching 30 years of age. It's probably dropped a couple hp but there is no magic to make it 30 unless you park a new one under it. Good excuse to update. Thats my story and I stuck to it.
Cant update to a newer tractor and dont really need to, this one is just fine. But I would like to know how to turn the pump up alittle. I know there has to be a fuel screw or somethin. All mechanical injection pumps have somethin you can fiddle with.
   / Ford 1700, more power? #6
Why do you think you need more power? Mine is identical to yours and I have pulled my 70 GMC heavy half up a 30 Deg. hill when it was dead. The tractor pulled it about 1/4 mile up hill, although for safty reasons I did it in reverse so the front end wouldn't flip on me. I hooked the chain to the front bumper of the tractor.
As for the straight pipe, I turned my muffler 90 deg and ran it straight out the back inside the fender. The only draaw back with that is you won't be able to enter or exit from that side. I have pictures and the muffler is still on the pipe. I like it that way because you can go under low hanging limbs without worring about knocking the muffler off.
   / Ford 1700, more power? #7
There used to be an adapter pipe to convert from vertical to horizontal exhaust, below the stepplate. Might still be avaiable.
I dont need more power. I just want more power. Im a car guy. I modify my vehicles to go faster and perform better. So I want to do the same to the tractor. I want the tractor to hold high rpm in high gear up a hill and not bog down. I dont care if it smokes actually i prefer it to smoke. So where is the srew?
   / Ford 1700, more power? #9
If you do play with the pump you will need to update to a newer tractor. Parts for these tractors are expensive. If you hurt the engine the repairs will cost more than the tractor is worth. If you buy a service manual it will show you what you want to know.
Bill
   / Ford 1700, more power? #10
Ahhh, the magic screw adjustment. Couldnt find one on mine either.:)
   / Ford 1700, more power? #11
Max travel of gas push rod to the injector pump to raise the fuel flow/rpm can be adjusted. That does not mean you can create more HP beyond what the engine can put out. Original poster final travel adjustment may be under-adjusted a wee bit. I would not monkey with it too much and if I plan to touch it, then for sure I would put a witness mark, paint or something on it to know where it was originally.
JC,
So what exactly do I do with the rod? How to adjust?
   / Ford 1700, more power? #13
The push rod is connected an arm that has angular motion from left to right. There are two screws that limits the movement of the cam (don't know what they exactly call it). study the motion by moving rod to the left and right and to see how the max travel is stopped. If you turn the right screw CCC you will have a bit more travel hence a bit more diesel fuel. I would not mess with it too much, I'd mark it first or try to remember how much you turned so you can bring it to where it is. in the pic below, next to gas linkage you see the screws I was talking about, the one on the right increases the travel in the direction of increasing fuel flow. Notice the jam or lock nut there to keep it from moving. Again look at mine that the position of it not only locked they used a wire and lead to make it tamper resistant. it is done at the factory, if your tamper proof still in place then I would not mess with it.
I only work it if the seal is already broken by previous owner.
JC,
   / Ford 1700, more power? #14
JC,
I just purchased a 1700 2 cyl.
You keep mentioning changing the injector pump oil.
What are the steps involved and what do you recommend for the oil.
I have already followed your advice on oil change, and the filter
numbers worked out great.
Thanks for all your posts.
Mack
   / Ford 1700, more power? #15
JC,
Mack
Mack,
Oil you'll be needing in the injector pump is the same as your engine /crankcase oil. I use the same Rotella or NH oil for diesel engine. On some tractors the oil between injector pump and engine is shared but not on Ford 1700. The procedure is extremely simple and should take you not more than 5 minutes to do it. I'd probably do it after running the engine for 5 minutes for the oil to get a bit less viscous. One time I used my portable air bottle and pushed a little bit of air from the top (fill point) and all the oil came out real quickly from the drain point. Look at the post #3 in the thread below and you have your answer.
JC,:)
http://www.tractorbynet.com/forums/...tor-pump-oil.html?highlight=injector+pump+oil
   / Ford 1700, more power? #16
I wonder if Macks's 1700 will be one of the ones without a drain plug on the injector pump, someone on here posted a picture of a pump without one. Hey Mack, how bout a few pics of the 1700, always nice to see other 1700's out there. TB
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
43023 (A59228)
43023 (A59228)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2017 ISUZU NPRHD 16' BOX TRUCK (A60430)
2017 ISUZU NPRHD...
