I'm curious what kind of tractor comes without a drawbar?
My Kubota 295DT didn't....someone cut it off...
I'd like to get a swinging draw bar for my B7200 but I haven't seen one on a machine yet.
Are they all the same?
Towing with my 3pt hitch can work but when backing the hitch can lift at interesting times.:confused2:
Anybody have photos of their swinging draw bar or of a method to keep the 3pt from lifting unexpectedly?
And it can happen quickly, too. Before you know it.
My question: When I need to pull something stout (like a stump) I attach a chain to the stump and to the drawbar holder (the part the drawbar attaches to). That is the same or better than actually turning the drawbar around and attaching to it. Right??
Right, I agree with you as long as you are pulling a load, towing something. Trying to remove a stump is somewhat different. It is an immovable object resisting the tractor's pulling strength, and when it eventually gives up and releases certain forces go with the release unlike a wagon or cart of dump trailer, haywagon, manure spreader, etc. Those object have wheels and are meant to be pulled/towed by a tractor/ vehicle. Stumps are generally considered to be objects that like where they are and have few plans of changing zip codesI will give this some thought. I always thought a drawbar (or at least what I consider to be a draw bar) to be the STRONGEST point at which a tractor can pull. I am not talking about anything to do with the 3pt or the FEL, but the bar that attaches under the center portion of the rear axle.I'm not saying you can't do it successfully, but it is not to my understanding the purpose of the drawbar, strictly speaking, and therefore it poses inherent risks greater than use for which the bar was intended.
I agree with that, and going easy until it spins or stalls.As a farm boy on Allis Chambers, and then on Deutsch, and then on JD, we hooked up anything and everything that the tractor would pull. We hooked it to the drawbar because that was the part of the tractor that would not tear up. I am not talking about yanking, I am just talking about hooking up, putting the tractor in the lowest pull gear available, giving a little gas and letting out on the clutch gently. Either the item comes along with the tractor, or the tractor stalls, or tires churn. I have always considered a tractor not to be strong enough to destroy it's drawbar hookup.
Guess you need a backhoe or a sacrificial chainsaw, as someone else mentioned.I will defer to those with more experience in knowledge, as it sounds like I have some un-learning to do. So far my CK30 has not been strong enough to pull out a stump more than 2 inch diameter, without some serious digging around it. I consider myself doing more damage to the FEL digging around it than to the drawbar unit pulling it.![]()
If You think it "stupid" not to know what a Draw bar is for? then you can call me "stupider"Ignorance is sometimes embarrasing, but I think I favor that over stupidity.
Draw bar:
Not that I need one, I don't know, but I've been seeing them around and I don't know what they are used for. So, let me have it. You can pound on me if you like, just slip the answer in there somewhere.
