JSUnlimited
I've read up on the KDP issue with the Cummins, and am aware of the 5 speed Dodge stick trani issues.
Best Rgds, D.
I think you have just answered your own question.
Best Rgds, D.
The "twin I-beam" front suspension has been a stalwart design and is TOUGH, especially true in the 4x2s.
The 4x4 3/4 and 1 ton Twin ibeam are not a very good front end. They are a weaker front end to begin with; Dana 50 as compared to the standard Dana 60 up front.
I'll second that. The twin I beams did not seem to hold up well on the working trucks I saw or drove.![]()
How long has it been since they used the Twin I Beam? I can not remember them in any trucks we have owned other than a 1986. All my Superdutys, a 99, 04, and a 06 all had solid front axle.
Chris
I had a 94' F250 with the solid front axle and presently a 97HD (old body) with the IFS.
Thnx guys.... that is exactly the general feedback that I was looking for.
Specific points are well appreciated..... I hadn't considered that nuance for the Boat/Tow site before. Will get the tow rating from DC tomorrow, and will chase the F250 specs too.
I tend to think of checking consumables pricing for printers.... good point flusher ! I'd suspect the wear/tear (engine wise) pricing for the 7.3 will be higher. Flusher - did you conclude anything concerning annual mileage vs. payback on a diesel vs. gas ? Also, thnx too... I was scratching
my head late last night as to what the HPOP was on the 7.3l.
. D.
The trucks I'm looking at are 2wd. While 4wd would be "nice to have" (for me), I prefer 2wd considering how long I hang onto vehicles.
Thnx for the detailed engine feedback ModMech - makes sense, as a medium duty engine, the 5.9 will have a lot more headroom in the design, if you really want to beat on it (performance wise).
The only upgrades I'd likely do on either truck is better air filtration (if needed), and a freer flowing exhaust. The goal would be efficiency, and cooler running. Any harm (reliability wise) with these mods on the 7.3 ?
Any "Injectors for Dummies"tm summary on comparing these 2 systems ? I have to admit to being ignorant (and a little confused, esp. re the PSD system - why have a 500psi oil requirement to operate a fuel injector ?).![]()
I'm wondering if the 7.3 HPOP is a dealer only item, couldn't find them at Advance Auto just now, sounds like these do go, and am trying to estimate cost.
I use Stanadyne Power Formula year round in my old Ag tractor (just to be kind), and would also use this on either truck.
Did I understand your post correctly - the Cummins fuel system is more sensitive to ULSD than the PSD ?
Thnx, Rgds, D.
Chris
The BIG advantage of twin I-beam is fewer wear parts over IFS while keeping the tire square to the road. After all, 99% of all 4x4s see very limited actual off-road use, those that do seem to see a LOT of off-road useTherefore, for most customers, on-road stability and ride quality is most important.
You should tell Ford you think their Powerstroke is a "medium duty" engine because even they don't think so and use the Cummins engine in their "medium duty" class 6 and 7 trucks. :laughing:They are both "medium duty" engines
The Powerstroke is NOT a medium duty engine, and does NOT like much more then about 50% more HP at most. I've seen plenty of failures.
Ford BUYS the 7.3L PSD (and 6.0L and 6.4L) from International, the contract between Ford and International says Ford CAN'T use the engines they purchase in the bigger trucks because International does not want their engines in competotor's MD trucks! Ford WANTS those engines in the MD lin-up, but they can't have them.
This is why the engine is rated as light duty versus medium duty.
The Cummins Turbo Diesel engine is renowned for its durability, being used in commercial medium-duty and heavy-duty applications worldwide.
The simple inline-six cylinder design has up to 40 percent fewer parts than competitive V-8 diesel engines. And the Cummins engine has an average life to overhaul of 350,000 miles, compared to 250,000 for competitive engines. Because of its longevity, the Cummins engine is rated as a "medium-heavy duty" engine, compared to the "light-heavy duty" designation for GM Duramax and Ford Power Stroke diesels.
Which MD trucks had the T444E? Besides School buses...?International sold hundreds of thousands of T444E (7.3L PSDs) in MD trucks
