arrabil
The big hill should be the deciding factor. The X700 will be a LOT more stable on it.
As for blowing snow with a front mount blower... both machines will produce identical results for similar pricing.
But if you need ground engaging equipment or a 3ph, you need to step up to a JD 2000 or Kubota BX.
The BX and X700 depreciate the exact same from an independent seller. The BX will fetch a higher price at a Kubota dealer much like an X700 will fetch a higher price at a Deere dealer. What you should do is get 50% off a X700 from Messick's after one of his new customers trades it in on a Kubota BX.
