Fuel Refilling Station
   / Fuel Refilling Station #1
George2615
Super Member
Central Square, NY
LS XR3037HC
Built my own tractor refueling station this weekend. Its a 15 gallon plastic barrel with an automotive type electric fuel pump powered by a small trailer battery. I got tired of holding a 5 gallon jug almost 5' in the air to reach the tractor tank. And since my tractor tank holds 8 gallons I'd have to use two jugs to fill it.
Its much easier to turn on a switch and refill the tank in a minute or so than waiting for the safety type 5 gallon jug to put some fuel in then suck some air before the next few ounces went in. (I hate safety jugs that don't have a vent hole)
The black piece on top is made from some 1/16" metal I wrapped around the tank, clamped then removed and welded. Then I welded a couple cross pieces to support the pump and battery. The battery fits snugly in a plastic electrical box. The entire unit is removable if I want to take the tank to fill at the truck stop or I can use the pump to refill it from the 5 gallon jugs.
   / Fuel Refilling Station #3
Mine is very similar in concept.
Added a suction tube to the pump inlet so that I simply stand it in the drum.
Also added an in line on/off switch and I take my 12 volts from an aux plug that goes directly to my battery.
That way I can transfer from a variety of containers.
   / Fuel Refilling Station #4
We love pictures.
   / Fuel Refilling Station #5
My diesel refueling station is the rear tank on the F-150! It was built with dual tanks and when the rear valve messed up I decided that it was better to by-pass it than risk another failure. I bodged up a hose from the in-tank pump with a brass quick-coupler and a el-cheapo plastic nozzle and when I flip the new switch to the rear tank the pump comes on and I can fill at will.
The factory switch is still in the dash and I tried to figure out a way to run the rear pump with the key off but nothing doing w/o major modifications. I figured it was easier to use a new switch with a fused B+ and the existing wires than to out-smart the factory switching.
I have still to get all the gas from the rear tank, remove the nozzle restrictor and label it "DIESEL" only, but at least the pump works :)
   / Fuel Refilling Station #6
I enjoy, and it looks like the OP enjoys, using off road diesel. I saved 64 cents per gallon today when I refilled my 55 gallon barrel with 50 gallons for 32$ savings!!! If you were to use the rear F150 tank for off-road diesel it might get you in a jamb when some uninformed policeman sees you filling a pickup tank with it. Sure, you could explain it away but you might not like the situation.
I use my bulk tank and a hand pump to fill the tractor directly or to fill the 5 gallon jugs for later pouring into the tractor since my 7 gallon tank will need to be refilled in the field when spending a day mowing.
Glad to see that the electrical fuel pumps are reasonably inexpensive these days.
   / Fuel Refilling Station #7
ORD would be GREAT if there was a local station that sold it :(
I think I'd have to drive about 45 miles, round trip, to get it. Sure, I'd save 50 odd cpg on the diesel but waste an hour or more and $9 worth of gas to do it. If I had a larger tank, like a 90+ gallon used truck tank, then it would make total sense.
   / Fuel Refilling Station #8
1*If you were to use the rear F150 tank for off-road diesel it might get you in a jamb when some uninformed policeman sees you filling a pickup tank with it.
1*You can't run diesel in a gas truck and the tank isn't plumbed into the trick engine so I see no problem.
My diesel refueling station is the rear tank on the F-150! It was built with dual tanks and when the rear valve messed up I decided that it was better to by-pass it than risk another failure. I bodged up a hose from the in-tank pump with a brass quick-coupler and a el-cheapo plastic nozzle and when I flip the new switch to the rear tank the pump comes on and I can fill at will.The factory switch is still in the dash and I tried to figure out a way to run the rear pump with the key off but nothing doing w/o major modifications. I figured it was easier to use a new switch with a fused B+ and the existing wires than to out-smart the factory switching.
Sounds like you are all set.
2007 JOHN DEERE 605C CRAWLER LOADER (A60429)
2007 JOHN DEERE...
DEUTZ MARATHON...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
JLG SKYTRACK 10054 TELESCOPIC FORKLIFT (A60429)
JLG SKYTRACK 10054...
(9) 55 GALLON METAL DRUMS (A60432)
(9) 55 GALLON...
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
