Happyman
Gold Member
What do you recommend for lube in there? My manual says either UDT (SUDT) or gear oil (80w).
One better than another?
I have always used gear oil. The gears hold up better, but the seals don't seem to last as long. With the UDT the seals last longer, but the gears don't.
Brian
please post the part #'s when ya get 'em from ronnie bowman
Almost sick engineering. I made a shim the same diameter of the bevel casing and tried a puller. Pullers are about as dumb as a bag of hammers, when they don't work. After fighting it I took a small chain and put it around the bevel planetary housing 'hub' with a 8 ton jack on my heavier now shim. Put the chain around the jack and (made) a portable press :confused2:You cannot imagine how much pressure it took, mind you, this part should "fall" off. As mentioned prior, it had to come off! It did, it pulled the oil seal out of it's fitted area (was getting new one anyway). The hang up was simple, there is the peiced together bearing ? and the top of it had changed 'integrity' hanging the whole thing up. Probably from the heat and wear. A new complete bearing set is on the way as well. I am replacing almost everything in that bevel houseing pdf I posted earlier. I will quote someone from earlier, the smaller the part the cheaper, usually" so why skimp now with it all apart. It had been failing for quite some time. I reccommend to all, change that bevel oil in your Botas, oil is cheap and this is 'catchable earlier'. THAT BEVEL 'SPINDLE' PART IS A CAST SECTION AND IT'S $500 WITHOUT BEARING AND ALL THE INTERNALS.
I know this is long winded but it was a heckofa day.......
