60" King Kutter Tiller
   / 60" King Kutter Tiller #1
iplumb
Gold Member
Mason MI.
B2920
Does anybody run a 60 King Kutter tiller with a Kubota B2920? They are on sale this week for $1399.00 seems like a pretty good deal. Just wondering how my tractor will handle it.
King kutter recommends 25 to 40 pto horse power. Thanks
   / 60" King Kutter Tiller #2
I run a 60" KKII on my 26.5 PTO HP L3240 and the only time I have bogged it down was in heavy, wet clay that loaded up the spool & added about 300 lbs to the tiller. BTW, the PTO clutch is a nice feature of this tiller and it's included in the price.
A lot of the HP requirement goes to keeping the tines spinning at 540 PTO speed in your slowest forward gear. This is an area where I think the HST has a distinct advantage as you can crawl at as slow a speed as you need to keep the spool spinning at the desired rpm. My tractor is gear drive and the first gear ratio limits how slowly I can move at 540 PTO speed (about 0.9 mph). As a result, when I'm in the heavy clay I need all of that power.
With the 2920 I would carefully assess minimum forward speed at 540 PTO speed as well as PTO HP before making a decision to buy.
-Jim
-Jim
Thanks for your input. Would you buy your King Kutter again? I may consider the 48" Just want to cover my tracks..
   / 60" King Kutter Tiller #4
I thought it might have been Tractor Supply but looking at their ad it's $100 off which is 1449.99. I called my local store to see if they had any and I mentioned that I had seen the price for 1399 and he said if I came and bought his, I could have it for 1399.99. Thanks for the heads up.
   / 60" King Kutter Tiller #5
I don't know about the KK 60" but my FIL has a Farm King 60" on his Kubota B2400 Hydrostatic and it has no problem even in the hardest/rockiest clay/soil we have around here.
Family Farm and Home $1399:thumbsup:
   / 60" King Kutter Tiller #7
To bad we don't have a Family Farm and Home around here. Although looking at their ad, it looks similar to TSC. Thanks again for the info. TSC has a 48 month low interest cc offer right now so I figured it was a pretty good deal.
Whats the rate?
   / 60" King Kutter Tiller #9
MAJOR PURCHASE PLAN*
7.99% APR WITH 48 MONTHLY PAYMENTS
$999 MINIMUM PURCHASE REQUIRED
Offer expires April 30, 2010
More info here: tsc
7.99% isn't that low but with the way the cc changes that have been made, it's not to bad.
   / 60" King Kutter Tiller #10
I run a 60" KK tiller on my JD 2520 and runs it just fine. 20.5 PTO HP.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2017 FREIGHTLINER...
2020 CATERPILLAR 259D3 SKID STEER (A51246)
2020 CATERPILLAR...
