Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Alot of it depends on the dealer.
As has been said.. when I have apiece of equipment in warranty.. it gets serviced by the book to make sur ethere are no issues.. past that, I usually keep dealer filters.. though go to non oem oils. For instance.. I have a NH7610s that had a deceftive remote pack.. one remote didn't work correctly... didn't find it till after warranty was up ( never needed both remotes ).. ended up being a flaw in the pilot circuit.. a physical defect.. etc. At the time we were chasing the problem, the svc manager knew I used walmart oil, and I specifically asked him if it was an issue.. He told me the hyds on my machine looked great, tested out to the correct psi and were otherwise fine.. the defect was just that.. a defect.. not a lube issue... fortunately he found me a salvage valve pack from a wrecked machines and saved me a few hundred bucks onthe repair.
soundguy
soundguy
Think again. Times have changed and a lot of dealers are looking to make money anywhere they can. My dealer tried to deny a warranty claim on my tractor, that took them over 3 months to figure out, because I had red fuel in it.
I bought my fuel fresh every month from the same supplier they got theirs from too. BUT my transfer tank is filtered. They use a barrel that is also used when they have to drain the tank on tractors. If fuel was dirty they did it.
They also tried to deny warranty on a leaky hydraulic o ring saying my oil was contaminated.
Probably from having my tractor for 3 months in their shop again trying to figure out why it wouldn't stay running. They told me they hooked it to several implements to load it and let it sit running.
I'm going to switch hydraulic fluids this month too. I'm looking for the right one to get and considering amsoil. I'm not paying what our local dealer wants ever again.
