Thoughts on using a Dump Trailer for hauling my Kubota?
   / Thoughts on using a Dump Trailer for hauling my Kubota? #11
I do see a few guys hauling their tractors around in big dump trailers. I thought it was a good idea when I saw that, but when I moved up to a bigger tractor, I had a hard enough time getting it on my 16' bp. I have not seen to many dump trailers that have a 16' body. I could not imagine trying to get it loaded in a box.
   / Thoughts on using a Dump Trailer for hauling my Kubota? #12
I have 2 trailers. A 16' equipment and a 12' dump. I can haul my B7800 in the Dump and do sometimes but not with any 3PT attachment on. I haul my L4350 on the equipment trailer w/ any attachment I want.
All this has been said before; Equipment trailer: Easier to chain down, lower center of gravity, can haul long items. Dump Trailer: Higher center of gravity, steeper loading angle, Restricted room when tractor inside, but you got it to dump and it does.
I do use the dump to haul my B7800 when I go for manure and then don't have that extra R/T bringing the other trailer, plus the time to hook and unhook. :thumbsup:
   / Thoughts on using a Dump Trailer for hauling my Kubota? #13
Just my .02 worth. If you are hauling just the tractor/loader and are only going to have one trailer, then yes go with a dump. They are heavier as mentioned earlier. I have a 10k lb 10ft box. The trailer weighs 3300 empty. Not exactly light duty and quite a bit heavier than my flat bed. You are definitely going to want some truck to be hauling your setup. No 1/2 tons or foreign stuff for this job!!
Also look into low profile dump trailers, that will keep your center of gravity a bit lower. Another trick, if you have a slight grade available on property, is load tractor with your truck/trailer pointed down hill. This will make for easier loading.
   / Thoughts on using a Dump Trailer for hauling my Kubota? #14
Thanks for asking this question, I'm in the same pickle as you. I have a JD 4720 and was looking at a 8x18 or 8x20 dump to haul it in, but I'm not sure if it is the right solution. I need something that I can dump with be it a trailer or a dump bed insert for my truck. I'd really like to kill multiple birds with one stone, but I also don't want to buy a big 'ol gooseneck dump and it not work out.
Any other ideas anyone?
   / Thoughts on using a Dump Trailer for hauling my Kubota? #15
Dump bed inserts are about worthless except for mulch and rose pedals. You can only haul a few tons at best. A true dump is a different story.
There is a guy on this site that has a heck of a trailer. I can not remember who he is but he had a custom built car/equipment hauler. Its a bumper pull 14,000# unit that has stake pockets and removable sides but is a full dump also. He had some pictures of it dumping firewood and it was slick. Great all around trailer.
Chris
   / Thoughts on using a Dump Trailer for hauling my Kubota? #16
   / Thoughts on using a Dump Trailer for hauling my Kubota? #18
It depends on what else you're going to do with the trailer. Do you need to haul stuff that can be loaded or unloaded with forks? Then a dump isn't for you. Do you need to haul dirt, stone, debris? Then you need a dump.
If you're going to have one trailer, you're going to have to compromise somewhere. Will you be using the trailer primarily for hauling your tractor, or material?
While tying a tractor down in a dump trailer is a little more difficult (allot more if you add side boards), there's an added measure of security in having the box to keep the tractor on the trailer.
The floor of my dump trailer is lower than the deck of my deck over flatbed.
I don't have any info about the brands of dumpers the OP mentioned. I looked at several brands before I decided to go with B&B (Behnke). It's 14' X 80" X 2' sides. 14K GVWR. It's hands down the best brand of dump trailer I looked at. Everything about it was built stronger or was thought out better than the other brands available around here. It has a single hyd cylinder with a scissor set up as opposed to twin cylinders that the cheaper trailers have. The single cyl set up is safer. That's why most HD dump trucks use them. The down side to B&B is the price. A 14'/14K GVWR dump will set you back over $7K compared to other brands in the $5K range.
Chris, That's a good looking trailer for hauling a tractor, lumber, firewood, etc. Doesn't look like it would be very useful for dirt, gravel, or debris because of the low sides and low dump angle. Still, it would be a good compromise for allot of folks.
   / Thoughts on using a Dump Trailer for hauling my Kubota? #19
Why do you say this?
Do I really need to explain? Average payload on a 1 ton dually maybe 3,000# Dump bed, 1,200#. What does that leave you 1,800#? My grandpas brother had a Eazy Dump dealership. We borrowed his demo truck once to get gravel and had to shove 1/2 off before it had the guts to dump it.
Chris
   / Thoughts on using a Dump Trailer for hauling my Kubota? #20
Well the title about says it. I am thinking of getting a Dump trailer 14' in hopes that it can do double duty of hauling my Kubota B3200.
What are other folk's thoughts and experiences?
What are your experiences with Big Tex or PJ 14' dumpers?
My dump trailer is 2x7x12 and has built in ramps. It caries my Kubota Grand L4610HSTC just fine. With FEL on the front I can park the bucket up on the front to get the tractor farther forward. With a 6 ft brush hog on back the brush hog rests on the trailer deck but sticks out the back so I have to leave the "French Doors" open and tie them to the BH. The bottom of my cab doors clear the 2 ft sides so getting in and out while trailer born is not a problem. With side boards... well, take the driver side sideboard off till you unload the tractor.
My dump trailer has HD "D" rings at all four corners of the deck for good tie down points if you are worried the tractor will jump up over 2 feet and get over the side. OK OK don't call the safety police, I secure it for highway travel but not local (on my property) travel.
A 14 ft deck would work even better than my 12 footer. My rear wheels have just an inch or two clearance from the sides so a larger tractor would require a larger trailer. I have a HD car hauler (18'3" on its steel diamond plate deck with partial dovetail which is my preferred tractor hauler) but sometimes the dump trailer is the best choice. I can haul the tractor to a site, unload the tractor, use it to fill the dumper, go dump, (lather rinse repeat), and then when through re-load the tractor and head for the barn.
Pat
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
HARRINGTON CHAIN HOIST (A52708)
HARRINGTON CHAIN...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2013 Wanco WTSP Folding Solar S/A Towable Arrow Board (A55973)
2013 Wanco WTSP...
