Angle of the Dangle
   / Angle of the Dangle #11
It's going to be a few more weeks before I get to install my T&T hardware...I can hardly wait...unfortunately power rippers are just a pipe dream for my little box blade (BushHog CBX60)...
I am considering an additional ripper of some sort that I can use to get burried rocks up with...
my mountain gravel road was originally bedded with river rock and later covered with different grades of crushed gravel...evey now and then I run across an "iceberg" rock where the top is sticking up just enough to push my bb up and the bulk of the rock is burried...I am thinking of some sort of ripper I can lower and dig around both sides of said rock until I can roll it out of the hole...right now I have to use a pick-mattock and dig them by hand...
Oh man, you are going to love that hydraulic top link, its GOLD! The tilt comes in handy as well.
Order of preference;
1. hydraulic top link
2. hydraulic tilt
3. rippers, hydraulic or other.
   / Angle of the Dangle #12
Loader is way quicker and much less hassle. I can work circles around a box blade with a loader and you would not know the difference in the finished product. I know I'll get an argument on this, but I'll stand my ground!
I'm with you on that point and do it often myself with my loader buddy.
   / Angle of the Dangle #13
I've read the threads on floating the FEL. On my B3030, I know it's in float with the joystick pushed all the way forward; if the bucket is up, it will float down when I do this; and when it's down with the wheels off the ground, it will float up. The stick stays locked forward until I disengage. Does the bucket just float up or down, or is it self-levelling?
D I have a self-levelling FEL? No matter what angle I put the bucket into, it does not skim the surface but digs in when going forward. Going backward, it seems to stay on top.
Am I missing something here? I would like to bucket in float position to be self-levelling as it goes over the surface of the ground, and not dig in at any angle. Or am I expecting too much?
Just about ALL buckets can be rolled in enough to give an angle between the floor of the bucket and the ground that will skim the ground when driven forwards, at least on level wet grass (-:
According to the nature of the surface the tractor might ride up onto the loader until it hits a stop, at that point you are hardly "floating" the bucket, the front wheels are off the ground and you are steering with the turning brakes.
It probably digs in if you are on deeply tilled soft soil, maybe deep sand.
It can be useful, for example when you need to return some of the material that back dragging has moved.
   / Angle of the Dangle #14
I totally agree with you. I also can can do good leveling with just the bucket.
ALTHOUGH... I like the box blade for the quick tilling of the material prior to the final leveling.
   / Angle of the Dangle #15
The advise given already has been right on. With float going forward works for a short time untill the bucket starts to dig in. In float, there is nothing stopping the bucket from lowering further down as thus digging further down.
   / Angle of the Dangle #16
Its easy to do a good job with the loader provided the soil is in premium conditions. I do it all the time with our associations L3940, even better with HST. I just never use float as I usually don't want the bucket to follow the ups and downs of the ground. If there are small mounds to take down, keeping the bucket close to flat 5 to 10 degs. and using the squared back edge of the bucket works beautifully. Often times I even leave a full load of dirt in the bucket for added weight. Try something hard and even our old now sold JD 410 backhoe just sits on top. Skidsteers operate this way almost exclusively provided again the soil is setup. In fact, I would venture to say I could do it much faster in our associations CAT 236B than any tractor. On the other hand, I much prefer driving/using the L3940 HST, what a nice tractor. Now if you want to talk really nice and easy, I also have a 8' Harley powered landscape rake. That's a whole different game.
   / Angle of the Dangle #17
I can say for sure that I need to practice with the FEL in float. This thread was a big help for those of us that are new to the home tractor world. I only wish that my CUB had the features of my new Kubota.
   / Angle of the Dangle #18
A little practice. I think the mistake most make is putting too much angle on the bucket. Try just a couple of inches space between the back of the bucket and the ground. Also, try it while not being in float. I have very limited use for float.
   / Angle of the Dangle #19
The best thing I ever did to my FEL was to add a bucket level indicator. Repeatability of the bucket angle is very important to getting the most out of the FEL. By knowing where the bucket is and noting what position works best for a given task I can do so much more that I could without it. A small angle change makes the difference between having the bucket dig in or ride up. Without a level indicator you have to eyeball the bucket and hope it is where you want it to be. Then by trial and error you find out if you guessed right. The indicator takes the guesswork out of it once you figure out what setting does what. As an example, I plow snow with the FEL on a gravel area at the end of my cement driveway. I can set the correct bucket angle, which I found from experience, and skim the snow off the gravel without digging in or rideing up. At the end of the push I raise the bucket and dump the snow. As I am backing up I set the same angle again with the indicator. When I start to go forward again for the next pass I power lower the bucket, push it into float and go forward again pushing snow not gravel . Much faster than trying to quess the correct angle all over again. The indicator is not so important for backdragging but it sure is for going forward. I made the one I have on my B3030 from simple materials. Very easy to do. Some say they don't need an indicator and just use the little flat bar on the bucket. I am not that good. The indicator makes all the difference for me for taking the frustration out of precise loader work. Good luck.
   / Angle of the Dangle #20
Every tractor I have ever owned came with a loader bucket level indicator. I agree, it is a very advantageous tool. The one on the Kubota LXX40's is very slick. Its adjustable and when you hit flat, you have a positive visual of it.
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2012 WESTERN STAR 4900 SB (A50854)
2012 WESTERN STAR...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
JCB 5 10 56 (A50490)
