I can not beleive I just did this - help please!
   / I can not beleive I just did this - help please! #11
I've got the 2620 - I don't recall seeing the extra cap, just the one on the rocker cover but it is a slightly different engine I guess. That's where I filled mine. What the heck is that other cap for? it's got to be the engine oil as well. I don't think I have that on the 26 hp. Wait for somebody with the 29 to answer and remember - don't panic - stay calm, you will figure it out.
Relaxing......:confused2::confused::mad::mad::mad::ashamed:
Thanks
I am trying to relax but cant. Is you tractor close by - can you run out and see if you have a Oil Fill right under the air-intake?
I dont deserve to be a member of the site.
So ashamed
AH!!!!!
   / I can not beleive I just did this - help please! #14
It could be that you simply haven't put enough oil in yet.
One thing that's for certain: you haven't broken anything - so as all the others say.. relax :D
I had a similar worry years ago, and it turned out that I wasn't putting the dipstick in all the way.
Try using a piece of wire that is a little longer than the dipstick itself: see it you "hit oil" with that. You haven't broken anything.... take it easy :)
   / I can not beleive I just did this - help please! #15
So ashamed
AH!!!!!
Take a pic of both and post them to see. It may be it has 2 oil fill caps.
   / I can not beleive I just did this - help please! #16
So ashamed
AH!!!!!
I will go out - it's raining and it's outside so you owe me- just kidding. I know mine holds a bit less than four quarts and yours should hold a bit more according the the manual. I think yours has a larger sump thus maybe the two caps - I will check mine now.
Here ya go guys.
806 - Show both Oil Fills
818 and 821 - The Lower Oil Fill (the one I used)
817 - The two drain plugs
What a nice Sunday.
   / I can not beleive I just did this - help please! #18
I've just got one filler cap on the rocker cover and one drain but it is a smaller engine. Man - I think I know your problem! You don't have enough oil in there yet. Mine didn't show until I was over three quarts and you have an even bigger sump. Start putting more oil in the top fill, you aren't up to the stick yet! - Man -I am almost sure that is it.
   / I can not beleive I just did this - help please! #19
It looks to me like you can use either hole to put oil in.
Did you add enough oil to hit the dipstick yet??
Hum....I dont know about that - I have almost the entire gallon in there now -its suppose to be 3.7 qts.
I am thinking maybe the sump has two sections and I filled up the one that doesnt show up on the dip.
ah man.
bstrom -I do owe you big time. Thanks bud.
2006 FREIGHTLINER COLUMBIA DBL SLEEPER ROAD TRACTO (A57192)
2006 FREIGHTLINER...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
40' CONTAINER (A57192)
2019 Deere 310L (A53317)
2019 Deere 310L...
UNUSED FUTURE 24" HYD TILTING BUCKET (A57192)
UNUSED FUTURE 24"...
Portable Restroom (A54865)
Portable Restroom...
