Oil & Fuel How Much Oil is in the Tank on a PT425?
   / How Much Oil is in the Tank on a PT425? #1
smartguyz
Gold Member
Beaverton, Oregon
JD318, Power-Trac PT425 with scuffed-up green paint.
With Autozone running a $6/quart special on Mobil 1, including the 20W/50, I was thinking of moving my PT425 over to synthetic oil. I can't seem to find any postings showing the overall capacity. How much oil would I need to buy?
-Rob :)
OK, sorry - I found it on the PT site - 10 gallons. T8 Class
So, at $24/gallon, that's $240 bucks!
Do you guys think its worth it?
-Rob :)
   / How Much Oil is in the Tank on a PT425? #4
The last time I checked, Mobil 1 15w50 was about $21 a gallon at Walmart... don't know what the current price is. If you can buy it in gallons, rather than quarts, it will be cheaper.
That's what I used to top off my system after installing the new wheel motors. I'd already changed the dino oil for Amsoil 20w50. Rather than hassle ordering another gallon, I just picked up a gallon of Mobil 1 at WalMart.
You'll notice a slight improvement in low-end torque, especially when working the PT hard such as mowing, and the hydraulic oil is hot...
Only you can decide if it's worth it. I will say that when I drained mine, at less than 300 hours, it was full of microscopic bits of metal that would glitter in the sunlight... makes me want to figure out a way to put a magnet in it to trap those suckers.
Thanks for the feedback, KentT.
I've considered either putting one of these in
Oil Filter Metallic Shaving/Particle Retainer - Oil Changes - Car Maintenance - Griot's Garage
Or possibly modifying the oil dipstick to have a honking-big-magnet dangling on the end of it.
-Rob :)
   / How Much Oil is in the Tank on a PT425? #6
Ken is going to chime in with his amazing magnet fix for the PT.
He sent me one I have yet to install.
That said, I just attach bar magnets to my filter. 3 or 4 high quality magnets to the trick.
   / How Much Oil is in the Tank on a PT425? #7
-Rob :)
The same amount that you would buy if you were getting dino.
   / How Much Oil is in the Tank on a PT425? #9
I had to go to at least two and maybe three Walmarts to get enough 20W/50 for my 422. Originally it had 5W30 dino. I noticed a big improvement in torque for that reason and torque does not fade as much when hot.
(18) 2" X 6" X 29" TUBING (A54756)
(18) 2" X 6" X 29"...
2006 JLG 3369LE ELECTRIC MANLIFT (A51406)
2006 JLG 3369LE...
(INOP) 2006 INTERNATIONAL 4300 SBA 4X2 26' BOX TRK (A54756)
(INOP) 2006...
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
