Lifting JD Ballast Box By Top Link Pin
   / Lifting JD Ballast Box By Top Link Pin #1
KennK
NE Wisconsin
John Deere 3320
If I have a JD ballast box filled with cement and try lifting it with a chain attached to the the top link pin ... will it support the weight?
   / Lifting JD Ballast Box By Top Link Pin #4
Yes, you can.
   / Lifting JD Ballast Box By Top Link Pin #5
Runner
Any weight in that ballast box ? :)
Could add chain support to the lower lift pins if worried about the top link pin (I wouldn't, but additional support, including a chain wrap around the entire box).
   / Lifting JD Ballast Box By Top Link Pin #6
"Runner
Any weight in that ballast box ?"
In the configuration you see in the previous picture, it weighs 473 lbs. With (8) 42 lb weights, it weighs 809 lbs.
   / Lifting JD Ballast Box By Top Link Pin #7
Runner
Nice rig :)
   / Lifting JD Ballast Box By Top Link Pin #9
Not always....:D
Sometimes.....
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
New Wolverine 44" Mini Skidloader Flat Bottom Grapple (A50775)
New Wolverine 44"...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
