Lifting JD Ballast Box By Top Link Pin
   / Lifting JD Ballast Box By Top Link Pin #1
KennK
NE Wisconsin
John Deere 3320
If I have a JD ballast box filled with cement and try lifting it with a chain attached to the the top link pin ... will it support the weight?
   / Lifting JD Ballast Box By Top Link Pin #4
Yes, you can.
   / Lifting JD Ballast Box By Top Link Pin #5
Runner
Any weight in that ballast box ? :)
Could add chain support to the lower lift pins if worried about the top link pin (I wouldn't, but additional support, including a chain wrap around the entire box).
   / Lifting JD Ballast Box By Top Link Pin #6
"Runner
Any weight in that ballast box ?"
In the configuration you see in the previous picture, it weighs 473 lbs. With (8) 42 lb weights, it weighs 809 lbs.
   / Lifting JD Ballast Box By Top Link Pin #7
Runner
Nice rig :)
   / Lifting JD Ballast Box By Top Link Pin #9
Not always....:D
Sometimes.....
Kubota LA1055 (A53314)
2008 Blue Bird School Bus (RUNS)(TITLE) (A50775)
2008 Blue Bird...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2018 KENWORTH T880 DAY CAB (A54607)
2018 KENWORTH T880...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
