Snow Push vs FEL for snow removal
   / Snow Push vs FEL for snow removal #21
Yes, good luck with the 3005, it's a sweet little tractor.
Rob
   / Snow Push vs FEL for snow removal #22
Any thoughts? I can't afford a blower but have not heard glowing reports of snow removal with FEL.
Thanks
Good = FEL
Better = front blade
Best = blower
I have a JD 4300 with FEL and front blade. We get on average 20-30 inches of snow each winter and the front blade can handle that. I've only had to use the FEL once in 10 years and that was for a 24" snow in one day. A FEL is not the best tool for snow removal on a regular basis because you have to fill the bucket then dump it somewhere ... very time consuming and hard on the tractor. Also whatever tool you decide to get, a set of chains for the tractor's rear wheels will make the job easier (especially in icy conditions).
   / Snow Push vs FEL for snow removal #23
If you are trying to keep the cost down give the FEL bucket a try. I have a 5' power angle blade on the Honda and yes it works well for light snow, but there is a limit as to how much the little machine can push. If I'd given it a bit more thought when ordering probably should have gotten the 72" FEL bucket since snow doesn't weigh all that much. I have about 350' of drive in a "U" shape plus a large parking area and mostly use the FEL bucket with the front edge tipped slightly up and in float position.
For the drive, I make one pass right down the center and unless it's a heavy snow fall usually don't have to stop until I get to the road. Then travel down each side and just veer off to the side as required and empty the bucket. A couple of additional passes clean up any debris that fell out of the bucket on the first passes. Except as a big boy toy, local conditions would not justify a blower, either front or rear. One day I might sell the Honda and buy a FEL blade for the JD.
If you order the 3032 with a 72" bucket, I'd think you could move a lot of snow quite easily.
   / Snow Push vs FEL for snow removal #24
JD755's pics illustrate exactly why i use/need a blower...the ridges caused by plowing would be a nightmare for me. whatever the level of the snow is, is how deep it will be in the drive way once the wind starts blowing. once you get a ridge working, the driveway will just pile in deeper and deeper.
if you don't have tons of snowfall, any of the methods should work.
   / Snow Push vs FEL for snow removal #25
I know you will enjoy your 3032E. Congratulations on your choice. Of course post pictures when you have it.
A front blade will be convenient, but you have to be cautious with a blade on the loader. It can produce significant side forces on the loader arms. I know others here have them and can provide more usage tips.
I really liked your pictures!
Saved the one of the 755...thank you very much!
   / Snow Push vs FEL for snow removal #26
Glad you liked it Roy. That machine has served me well for very many years and been really trouble free. I still enjoy every time I use it.
   / Snow Push vs FEL for snow removal #27
I imagine that when plowing snow more speed is used thus amplifying the forces. This must hold true for a wide bucket then too.
   / Snow Push vs FEL for snow removal #28
Not really. An angled blade will tend to push the loader to one side. The force on a bucket is typically straight back toward the tractor.
   / Snow Push vs FEL for snow removal #29
So i would presume that a fixed straight blade would exert no different force than a bucket.
   / Snow Push vs FEL for snow removal #30
Wouldn't be the first time a loader frame got sprung. Deere does sell a QA front blade for the loader so I guess they have some confidence in the loader frame. It's got a tripper and, IIRC, a nonmetallic wear strip at the bottom of the blade. Pretty nice, actually...about $3K, I think.
1272 (A50490)
1272 (A50490)
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
1998 Jeep Cherokee Sport (A50123)
1998 Jeep Cherokee...
(4) 5 LUG WHEELS & TIRES (A51248)
(4) 5 LUG WHEELS &...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
