Ford 1710 final drive
   / Ford 1710 final drive #11
The mystery continues. We need some answers from another 1710 owner.
Two thoughts come to mind for this (only speculating) 1) Make sure you added enough trans fluid while changing it as the 4x4 housing may get oil from overflow from the tranny. Did you replace 19 US qts of fluid in the trans? Remember when checking the dipstick level, do not screw it into the housing, check while unscrewed.
2nd if fluid is correct try engaging the 4 wheel drive for a short distance to see if some fluid comes into it.
I am running out of ideas here.
   / Ford 1710 final drive #12
i have a 1710 that sounds like yours but my owners manual doesn't go up to pg.93. There is a dip stick for the tranny/hyd resevoir.
   / Ford 1710 final drive #13
Darrell is refering to the shop manual. It is more detailed with overhauls and repairs than the Owners manual so it has more pages, but any input you can give him will be appreciated. Ray
   / Ford 1710 final drive #14
I don't have my manual with me, but I've got a 2 wheel drive, and I've never pulled a plug that didn't have something come out. If I remember correctly...Ther's a drain plug for the trans, then a drain plug for the diffy, and then a drain plug under each axle housings. When draining the diffy, there should be 3 plugs to drain.
Gentlemen,
Mystery solved!! I pulled both plugs (right and left hand) and stuck a screwdriver up there. It was all crusted over not allowing fluid to come out. It is filled with hydraulic fluid from the main reservoir. I called the fella I bought the tractor from (a small tractor dealer) and he said I should drain the hydraulics again and fill the hydraulics with diesel and run the tractor. He says it will dry out any water left in the system. Then I can refill it with hydraulic fluid, change the filter, and be good to go.
Thanks again,
Darrell
I'm using hydraulic fluid that's 32 weight. Is this correct? I also saw they sell a 46 weight and one other.
   / Ford 1710 final drive #17
Darrell the correct fluid for the Transmission, rear axle and Hydrolic System is Ford M2C-134A This also runs the 3 pt lift. (and the FEL) It looks like auto trans fluid, and I think it is less than 30 wt. Check with a tractor supply or New Holland dealer. You can buy it in 5 gal cans. If what you put in your trans is too heavy it's going to slow everything down and cause problems. Make sure you get this right as it is extremely important. Maybe the reason the fluid didn't come out the drain holes was because it may be to thick.
   / Ford 1710 final drive #18
Do not use hyd. oil. Use the specified oil. Hyd oil will not cushion the gears in the trans and rearend and will cause premature wear. I would use Seafoam `transtune to get rid of the moisture.
Bill
2015 Chevrolet Cruze Sedan (A50324)
2015 Chevrolet...
Swict 72" Bucket (A50121)
Swict 72" Bucket...
John Deere 648H Grapple Log Skidder (A50322)
John Deere 648H...
TEST BID LOT (A50775)
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
Mini Excavator Attachment Set (A50121)
Mini Excavator...
