BX lost steering
/ BX lost steering #1
Camo
Southwest Pennsylvania
I got a 2004 BX2230 and was doing my mowing this morning when I noticed something odd about the steering feeling "dead" a couple of times. I stopped and checked it out to find that if I turn the steering wheels very slowly to the left, the hydraulics for the steering do not react until I turn the steering wheel faster, then the tires steer left. steering to the right is 100% normal. I was never able to locate a kubota service manual for this tractor, so I have little insight on this. Has anyone seen this before, and/ or know where I need to start looking?
Thanks in advance!!!:thumbsup:
/ BX lost steering
/ BX lost steering
Update, I thought it was only doing it to the left, but it is both ways...Seal kit on order, but will work on finding the size of the o-ring to post up on this site. :thumbsup:
/ BX lost steering #7
Does this happen with heavy FEL use?????
Heavy FEL use would put more strain on the powersteering since there is now more load on the front wheels. FEL work almost always requires lots of turns also which could shorten the life of the steering cylinder seals.
Try to limit the amount of turning you do while sitting stationary. This also puts extra strain on components especially with a loaded FEL.
Roy
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
1997 MACK MIXER (A65643)
1997 MACK MIXER...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
