Plow
   / Plow #1
browndd1
Member
Can anyone tell me how big a plow a ford 5000 diesel tractor (69 hp) will handle?
thanks
   / Plow #2
3-16" ought to about do the trick. 4-12 or 4-14 in soil that is not compacted may be possible. Ken Sweet
   / Plow #3
3-16 in my heavy clay soil.
Some might try a 4-14 in lighter soils, but - you can always drive a little faster; but if you spin out with too big a plow then what?
--->Paul
   / Plow #4
thanks
Is this pull type or semi mounted plow?
What type of soil conditions and terrain? I.e. Flat or hills.
Pull type 3-16's will be a load under most conditions. Breaking Sod it may be to much.
We pulled a semi mounted 4-16's in corn stubble and lighter soils with our 5,000. Power wasn't the issue it was weight. We had 15-5 x 38 tires with fluid in them and it was still a weight issue.
In Sod or tough ground we had 3 -14 pull type and that was all it wanted due to traction issues.
Another problem was the front wants to star gaze real easy with the semi-mounted. We had a rock box that we filled with rocks. Weight???
For all around use I would recommend semi-mounted 3-16's and probably 4th gear in normal conditions and 3rd in hard going.
Roy
   / Plow #5
Agree with above posts. I've heard that 20 - 25 HP per bottom (depending on soil and size: 12", 14", 16") is a good guess.
That would seem to fit with the previous recommendations.
Adams 5T Pull-Type Fertilizer Spreader (A55314)
Adams 5T Pull-Type...
202475 (A54757)
202475 (A54757)
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
SKID MOUNTED WATER PUMP (A55745)
SKID MOUNTED WATER...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
