Plow
/ Plow #1
browndd1
Can anyone tell me how big a plow a ford 5000 diesel tractor (69 hp) will handle?
thanks
/ Plow #2
3-16" ought to about do the trick. 4-12 or 4-14 in soil that is not compacted may be possible. Ken Sweet
/ Plow #3
3-16 in my heavy clay soil.
Some might try a 4-14 in lighter soils, but - you can always drive a little faster; but if you spin out with too big a plow then what?
--->Paul
/ Plow #4
thanks
Is this pull type or semi mounted plow?
What type of soil conditions and terrain? I.e. Flat or hills.
Pull type 3-16's will be a load under most conditions. Breaking Sod it may be to much.
We pulled a semi mounted 4-16's in corn stubble and lighter soils with our 5,000. Power wasn't the issue it was weight. We had 15-5 x 38 tires with fluid in them and it was still a weight issue.
In Sod or tough ground we had 3 -14 pull type and that was all it wanted due to traction issues.
Another problem was the front wants to star gaze real easy with the semi-mounted. We had a rock box that we filled with rocks. Weight???
For all around use I would recommend semi-mounted 3-16's and probably 4th gear in normal conditions and 3rd in hard going.
Roy
/ Plow #5
Agree with above posts. I've heard that 20 - 25 HP per bottom (depending on soil and size: 12", 14", 16") is a good guess.
That would seem to fit with the previous recommendations.
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2018 Dodge Charger (A61574)
2018 Dodge Charger...
JOHN DEERE 8 SHANK CHISEL PLOW (A63291)
JOHN DEERE 8 SHANK...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
1980 FRUEHAUF 45' T/A FLATBED TRAILER (A59911)
1980 FRUEHAUF 45'...
