TC33D won't start.
   / TC33D won't start.
Thank you for the replies.
All the fuses are good. The engine does not turn over. I called my NH dealer and he seems to think it is in PTO switches.
I will investigate that tomorrow.
joe
Good News, It was a loose wire.
   / TC33D won't start. #16
My new T2220 did this last week after bush hogging. Two wires underneath the tractor pulled apart at the connection. Easy fix but dumb place to leave two wires hanging underneath the tractor. :confused3:
   / TC33D won't start. #17
Ok, I want you all to know that your response is what helped me fix the same issue I had with mine. Brush must have pulled the PTO wire loose underneeth. I agree that's a bad place to put wiring. I can't tell you how trilled I am to get it working. Now I can continue my 2 wks of vacation moving dirt which beats going into the office any day of the week. Funny thing, my kids call the tractor's PTO "Paid Time Off". Thanks for all your help.
   / TC33D won't start. #18
I believe my PTO switches and hardware on my TC35 are indentical to what you have on your TC33. That PTO switch is always something to pay attention to. For instance, I had that same problem years ago when I first bought my machine (back in '04). Was running it during a snowstorm, trying to get lumber in the barn before it got buried! Stopped the tractor at one point, and then went back to it 5 minutes later....The darn thing wouldn't start!! Tried what I thought was everything, and then had to abandon "blue" in the snow...
I had just become a TBN member then, so I went home and described the problem on this very forum. TA DA! Someone suggested, and I think it was Jinman (was it, Jinman, maybe you remember....), that I might have moved the PTO switch by accident. Went back to the machine, and sure enough, I had accidentally hooked the level and just moved it about 3/4" out of "true off". That was enough to pull the lever stop off the safety switch, and convince the tractor that the PTO was "on".
Moral of the story....pay attention to that darn switch (and in your case, the wire,too)!!
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
