Zerks just pull out!!
/ Zerks just pull out!! #1
Poacher Hater
Member
Has this happened to anyone but me? When I pull the grease gun off the zerk of my chipper, the zerk pulls right out too and it is almost impossible to pull zerk off of grease gun coupler. Then the same thing happened on my boat trailer zerk! Two grease guns, both do same thing. Bought a different coupler at hardware store today that is adjustable, but everyone I talk to "has never heard of this happening". The zerks are just push in, not threaded.
/ Zerks just pull out!! #3
Then they haven't had much experience with grease guns and zerks.:D I think it fairly common with pressed in fittings, but seldom happened with screw in fittings on cars and trucks.
/ Zerks just pull out!! #4
What do you have for a chipper.??
/ Zerks just pull out!! #5
Are you aware that the amount of grip the grease fitting has on the zerk is adjustable?
Sometimes the factory setting is so tight, it you could tow the vehicle with it.
It doesn't seem adjustable, but the new one I got is. I will look at it better tomorrow.
/ Zerks just pull out!! #8
I would suggest rethreading the hole, retapping and put in sae or metric screw in type zerks. While tapping, Be careful to avoid getting metal chips where they don't belong. That will stop that foolishness. Ken Sweet
/ Zerks just pull out!! #9
Self-tapping zerks are available -- I ordered some through Fastenal. I haven't used them yet so I can't say how well they work.
Steve
/ Zerks just pull out!! #10
Steve
Let us know how they do? That is a great idea. I wonder if they offer them in a assortment box SAE and Metric? Ken Sweet
/ Zerks just pull out!! #11
Ken,
The only ones I found after a search (admittedly brief) were 1/4-28". There may be others out there.
Steve
/ Zerks just pull out!! #13
I'd swear I've about 30 different size zerks out of 20 on my ride. It seems almost every time I go to pull the hydraulic coupler off the zerk it is to tight, then the next one I go to put the coupler on it's way too loose. But in about 40 years of using grease guns on cars and motorcycles I rarely had to adjust the coupler.
Where would be a good source for high quality replacement zerks that would be a uniform size?
/ Zerks just pull out!! #14
I have used the self tapping zerks and they seem to work quite well. I can't tell you where to get them, I got an assortment box full of them from Caterpillar. Although I have seen similiar assortment boxes at the local Napa. If you want an assortment that are pretty much a uniform size, that's the route I would go.
/ Zerks just pull out!! #15
Just had two of them pull out of my deck wheels yesterday. :mad:
Didn't realize they made tapered zerks till I looked at them, thought at first they were stripped.
Guess it's time to look for some self taping zerks.
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
John Deere 1023E (A62177)
John Deere 1023E...
