dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,006
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
So a friend of mine sent me his old skidding winch, a Farmi JL304 that is right about 30 yrs old. He used to use it on his Ford 9N for his firewood business when he was in high school and college. It had been kicked around a lot over the years and was in sad shape with the main post bent and needing bearings and a lot of cleaning. So I got the post fixed, and they also straightened out the severely bent guard that was binding up the drum. New bearings, new hardware, clean it up, fresh grease everywhere, and we took it out to give it a test run.
Got it mounted on the L3130 no problem, and only had to spend a little time adjusting the clutch to get it working correctly. So we try it out on a small log, and it works great. Then pull a large poplar and it zips it right along. So we go to grab a decent sized oak ~16" dbh, and it won't budge. It wasn't slipping the clutch it actually stopped the PTO shaft dead at full clutch engagement:shocked:. Obviously that isn't a good thing, so I quickly released the lever. Tried again a few times and same thing. It dug the winch feet in deeply but would just stall the PTO in the end.
This tells me I need more hp if I really want to run this. I don't consider this one a huge tree, so I really was surprised it wouldn't move. So the question is how much do I need? I would stick with an L-series as it is the right size overall, so I'm wondering which engine would be about right. The only thing I have for info on the winch is the label that says 30kN max 10 kN min. That doesn't do me a lot of good as PTOs are rated in KW or hp (power, not force) and besides, which force? The pull on the cable or the input? No clue.
I guess I'm just fishing for any experience others have in sizing the tractor to fit this application.
Thanks,
Dave
Thanks,
Dave
