Money is tight, need a home. Something plain jane, even if it's just dried-in. Trying to avoid getting a mobile in central florida. Any ideas? Thanks.![]()
That sounds like a challenge. Will you have town/county water and sewer? I assume your foundation will be a concrete slab? How about the Florida hurricane building codes?
You will have to make every inch of your building materials count.
From a purely financial aspect, the mobile may be a better use of your money if you end up skimping everywhere on a new build. Have to watch your resale value.
Dave.
If you do most of it yourself, and you are building in a county with little building codes, and you already own the land.
Around here you get to pay "impact fees" of around $10K, not counting the permit fees which can be a few more K's. And you get nothing for the impact fee's, it's not a water tap or sewer tap, just an impact on your wallet.
A challenge indeed. I have a well and septic ready to roll but will need a slab. I peeked at the florida building codes but they are thousands of pages long and I don't understand any of it.
For around 33-34k I could get Kodiak Steel Homes | Autumn View Series this 1170sf model delivered. Red iron bolt-together steel construction with PBR roof panels and steel siding (no windows, doors, interior, or labor). I wonder what it would cost to erect this and put in "dry-in" condition?
Or the mobile might be a better idea? Concrete blocks are cheap here too, i wonder how much it really costs to put something small and simple together. Nobody will build anything here under 90k+ it seems.
Around here the Mason's charge a $1 a block or more tp lay them. Not sure what they charge in Florida. With cement block walls you will have to either run all of your electrical through the cores of the block in conduit or on the surface in conduit. All of these items make cemnt blocks an expensive option quickly.
Materials for a 800 SF addition including foundation are costing me around the $45K
Are mobile homes approved for hurricane areas?
Roy
very good points guys. thanks alot for all your insight. this would be more of a permanent thing, not temporary. It's starting to look more and more like a mobile is the way to go. Are there any special things that can be done to make a mobile more stout? Any advantages to putting one on a slab?
