3pt hitch Bx23 vs Bx24
   / 3pt hitch Bx23 vs Bx24 #1
evilgriff
Does anyone know if the hitch kit for a bx 24 will fit a bx23? Are most of the parts the same? I cannot find a parts list for what is supposed to be in each kit.
   / 3pt hitch Bx23 vs Bx24 #2
I'm pretty sure they are not compatable. The mounting pins for the BX23 are permanently secured in the subframe whereas the mounting pin for the BX24/25 is installed along with the rest of the assembly and removed when the 3ph is removed.
The BX23 3ph is a simple tool-less R&R, from what I've read of the new style BX24/25, it isn't.
   / 3pt hitch Bx23 vs Bx24 #3
The assemblies may appear similar at first glance, but they are actually different; and most of the parts are not meant to be interchanged. Although the lift rods from one will fit the other, that are in fact of different lengths. Which kit are you looking for: the BX23 or BX24?
Still looking for a bx23 hitch. If anyone comes across one let me know. I bought my bx used and it did not come with one. Haven't taken off the backhoe yet-- I would like to finally try using this tractor for more things.
   / 3pt hitch Bx23 vs Bx24 #5
I got one off of fleabay about a year ago was apx $100 if memory is correct. Don't think I've seen once since. Sorry.
   / 3pt hitch Bx23 vs Bx24 #6
I know my 3PT hitch on my BX24 sucks compared to my old BX22.
   / 3pt hitch Bx23 vs Bx24 #8
Hmm that's interesting, which model started using the full cat1? The BX24?
   / 3pt hitch Bx23 vs Bx24 #10
the old BX's where limited CAT1, the new ones are full Cat1... so the geometry is different.
Point I was making is the set-up on the bx24 is not as easy as my old 22..The old 22 was much easier and less parts.
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
CAT 930M (A58214)
CAT 930M (A58214)
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
