Removed the FEL
/ Removed the FEL #1
kosby
KY
Kubota B2320DT
Never mind the cluttered garage (a man will resort to all kinds of things to make a new toy fit and nearly take a cussing from the wife explaining why room wasn't made for her car). Anyway, I decided to take the FEL for two reasons, 1. to learn how and 2. make things easier while mowing. It was pretty simple to do. Followed the instructions but didn't really lift the front wheels, or at least it didn't appear to . After lowering the stands, I lowered bucket and rolled it slightly keeping pressure off stands. The right side pin pulled out easily. The left pin was a little stiff so I bumped the control lever a second time and it too slid out with no effort. Then rolled the bucket back slightly and it lifted out perfectly. This is a lot simpler than it appeared to me.
/ Removed the FEL #2
Congrats...You can appreciate the effort that went into making it that easy.
/ Removed the FEL #3
Amazing piece of engineering, aint it! A few more times and it'll be like second nature. Just remember to rotate the joy stick in all directions to equalize the pressure in the hoses before you unhook it. If there's too much pressure in one of the hoses, it can be a real "beach" to get it plugged back in.
Tell your wife her car will depreciate much faster than your tractor, so putting that in the garage is the smart move financially, :laughing:
/ Removed the FEL #4
Congratulations! :thumbsup: now for the fun part, reinstalling it.:D
/ Removed the FEL #5
We don't need no stinking FEL's.........till we do.
Don
/ Removed the FEL #6
I took mine off my L5030 yesterday to replace the belts, it comes off/on just like my BX2660, very easy and less than 5 minutes; gotta love em.
/ Removed the FEL #7
I have come this close -><- to removing mine for the very same 2 reasons. Thanks for the info. I have also been considering just removing the bucket while mowing. That thing is a fence snagger.
/ Removed the FEL #8
They have surely come along ways removing fel since old days..mins compare to hours.
/ Removed the FEL #9
I have done/do both and while removing just the bucket helps, removing the whole unit works better especially in regards to visibility at least on my tractor.
That being said, as easy as it is to remove the FEL, it is even "easier" to drop the bucket with QA, so I guess it just depends on what works for each person/application.
/ Removed the FEL #10
You guys need to try the Deere for quick and easy remove and install of the FEL :D
No pins to line up. Drop the FEL without getting out of the seat until disconnecting the four hyd. hoses. That is what is "easy".
(Now, if there was a way to make quicker/easier hyd. hose connectors :) )
Sorry for infiltrating the thread with green. :D
/ Removed the FEL #11
Well for me, I don't care for the John Deere brake setup on the size tractors I use and in my area they are quite a bit more expensive.
No problem with invading, the more people know the better able they are to make the best selection decision.
I own a Deere too as well as Case and MF.
Oh, I also have a ground crew to pull pins etc.
/ Removed the FEL #12
Kosby - Can you post some pics of your 3200 w/out the FEL on? How many hours you got on that puppy? Looks emaculate.
/ Removed the FEL #13
i am 50-50 (only have had the FEL off 4 times) with the hoses going right back on, when i do have some pressure in the line i break loose a fitting on the FEL. and everything is fine.
how do you like that mower? i have the same one and like it alot but still learning the swing when i come to the corner post in the fence :laughing: and the fence show it.
/ Removed the FEL #14
Been wanting to drop my loader, just to do it. But it looks so intimidating, maybe I'll try now, you convinced me.
/ Removed the FEL #15
Does any oil drip out when you disconnect the supply hoses?
/ Removed the FEL #16
/ Removed the FEL #17
More Green influence... I can't believe the FEL dis/connect is much different between colors. I don't think twice about removing mine whenever I feel like it - it's too easy. If you mow with the FEL on, take it off once and mow. You'll never mow again with the FEL attached! Yeah, a little oil drops out of the QDs, but I put a shop rag below the connects and wear latex gloves (don't like being oiled, and here come the Deere jokes...). Takes all of 5 minutes to be finished and put away. In hot weather, though, the oil can expand in the unconnected FEL hoses, making it near impossible to reconnect the QDs. I've had to resort to a block of wood and channel locks to depress the QD stop and release some pressure.
WARNING: If you do that you MUST wear eye protection. MUST! It will spray everywhere - soaking you and whatever is around you. And it sprays hard - it's under a lot of pressure, and don't think you can cover it with a rag and be safe. You just do not want that oil going into your eyes under pressure... I've found it best to reconnect in the early morning, before everything heats up, if you keep it parked outside in the sun (like I do).
/ Removed the FEL #20
All I can say is, WOW. I have had my 2630 for only a couple of days and I was worried about how difficult it would be to remove the FEL. I mowed a bit with it on and realized I would prefer not to but I was worried it would be hard to remove. I read the instructions and had it removed within a couple of minutes. Definitely will keep it off and just install it whenever I need it. Amazingly simple.
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
Metal Sasquatch (A65583)
Metal Sasquatch...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
