How do you support you PTO shaft
   / How do you support you PTO shaft #11
Boone, how do feel about some small cinder blocks to set that on ?
   / How do you support you PTO shaft #12
Willl
Thanks for good advice.:thumbsup:
The pictures there were before I hooked-up to run Hog on back three acres.I sit mine down when not in use on 4X4's(pressure treated)flat on ground of course.Covered by tarp and all components well greased.No more room in shop.The Bush Hog and my 1958 Servis E3wm rear blade have to sleep outside.
Heres also a pic of my Cosmo 500 seed spreader(upside down)on bench w/screwdriver holding short pto shaft"in place".:D
Boone
(ROPS down cutting under some trees)
   / How do you support you PTO shaft #13
Wood ain't going to do, treated or not, put it on blocks.
   / How do you support you PTO shaft #15
I use the kind of cheap chain they make for dog runs, kind of a double link, maybe 10 ga. wire. Clip the ends together with a snaffle, real simple and lasts a long time.
Jim
   / How do you support you PTO shaft #17
Jim
What is a snaffle?
   / How do you support you PTO shaft #20
What is a snaffle?
Don't know the right name. It's the thing just to the right of the purple carabiner in the photo. You see 'em on horse leads and such, someone probably knows what to call it.
Jim
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
