How do you support you PTO shaft
   / How do you support you PTO shaft #11
Boone, how do feel about some small cinder blocks to set that on ?
   / How do you support you PTO shaft #12
Willl
Thanks for good advice.:thumbsup:
The pictures there were before I hooked-up to run Hog on back three acres.I sit mine down when not in use on 4X4's(pressure treated)flat on ground of course.Covered by tarp and all components well greased.No more room in shop.The Bush Hog and my 1958 Servis E3wm rear blade have to sleep outside.
Heres also a pic of my Cosmo 500 seed spreader(upside down)on bench w/screwdriver holding short pto shaft"in place".:D
Boone
(ROPS down cutting under some trees)
   / How do you support you PTO shaft #13
Wood ain't going to do, treated or not, put it on blocks.
   / How do you support you PTO shaft #15
I use the kind of cheap chain they make for dog runs, kind of a double link, maybe 10 ga. wire. Clip the ends together with a snaffle, real simple and lasts a long time.
Jim
   / How do you support you PTO shaft #17
Jim
What is a snaffle?
   / How do you support you PTO shaft #20
What is a snaffle?
Don't know the right name. It's the thing just to the right of the purple carabiner in the photo. You see 'em on horse leads and such, someone probably knows what to call it.
Jim
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
Countyline Single Row Cultivator (A50123)
Countyline Single...
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A51248)
INGERSOLL RAND...
