Trailering Tips
   / Trailering Tips #1
davatk
Gold Member
Flint Hill, Virginia
Kubota B2630
Well I finally made it down to Barlow country and picked up my trailer last Friday. It is a 16' Gatormade Utilty with rear gate. I really like it alot and it pulls very well. :thumbsup:
When I went to load my B2630 w/ FEL, and bushhog, lo and behold it was a bit to long for the trailer. I ended up taking the rear wheel off the bushhog and even then had to hang the bucket over the front of the trailer. Obviously didn't have much if any room to postion the load for balance and tongue weight, so I may have been a bit heavy up front.
Anyhow, just wondering what others are doing when loading with similar sized tractors w/ FEL and a rear implement such as a bushhog. Removing that bushhog wheel is a bit of a PITA, but I guess I'll get used to it.
Thanks !
   / Trailering Tips #2
I usually measure what I want to pull before I buy the trailer.:D
Just joking - I know 16 feet is about the most any of us home duty guys would want to pull. Will you really be transporting it that often? What about modifying the trailer to wrap around the wheel?
   / Trailering Tips #3
18 ft (16 ft on the floor + 2 ft tail) and a FLAIL mower is a nice fit, even with slightly bigger tractors.
Flails are about the same length behind the tractor as roto-tiilers.
Having a flat on the truck helps too, can't fit much between those wheel wells in a tin pick-it-up bed (-:
   / Trailering Tips #4
Since you have the tractor and all the equipment, I won't suggest you buy something else you really don't need.
I have had to remove a portion of the equipment and on one occasion, could not fully close the tail gate. All I have ever been able to do is to do the best I can to get it to fit and this often means putting the bucket over the front.
A lot is going to depend on how often you have to haul your tractor to determine if it is worth making major modifications to your equipment to make it easier. I don't trailer often, so I just do what I have to do to get it there.
Good luck
   / Trailering Tips
Yea, I battled with the 18' but just couldn't bring myself - already feels like I'm pulling a house around. Honestly I will probably have the bucket off most of the time when I use the bushhog, but would be nice to have it attached sometimes if I ever need to use the both of them where I am transporting to.
   / Trailering Tips
Good luck
Thanks for the advice. That's kinda where I'm at - when I need to trailer the entire rig, I'll just have to improvise. I'm just trying to figure out what is the best impovisation at this point. :D
   / Trailering Tips #7
I was going to get a 16' for my use, now I'm up to a 25' +5 gooseneck that I'm looking at.
   / Trailering Tips #8
Just out of curiosity, what's your tow vehicle?
   / Trailering Tips
I am currently towing with a Honda Ridgeline - 5000# max tow capacity. Handles the load OK, no powerhouse. The Ridgeline is a fairly heavy vehicle for its class, so that helps.
   / Trailering Tips #10
OK. Well it can't be as bad as my one friend that's pulling a 20' enclosed car trailer with a 4Runner. He has all the sway control, load-distributing, etc. crap he's supposed to, but it still looks pretty comical going down the road, especially with his extra-super-wide-side-mirrors. You can't tell which end is in charge. :D
I've pulled an 18' with my Silverado 1500 and thought it was fine, but the 'rado is just a little bigger/heavier, etc. Except for my dump trailer, I'm trailerless at the moment though, but plan on getting another 18' flat bottom to double as both a tractor/car hauler.
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
