Poles for Pole Barn Sizing
   / Poles for Pole Barn Sizing #1
jcook5003
Hey Guys-
I'm looking to build a small horse barn on my property, I am going to build it 36x36.
I was going to use free span trusses with a 4:12 pitch and for posts I was thinking of using 20' 6x6's notched for a double 2x12 header to support the trusses. I looking at having a 16' sidewall height.
Do you guys think the 6x6 is a big enough post for this application? or should I upsize to an 8x8 or even 10x10? It seems most people use 6x6's and do fine, just wanted other opinions.
   / Poles for Pole Barn Sizing #2
Welcome to TBN.
You didn't fill out your profile or state where you live, as this will have some bearing on your decision. Heavy snow loads? Hurricane alley? These things make a big difference. Shooting from the hip, I'd question 6x6 for 36' span and roof load, but ymmv.
I live in Blacksburg Virginia, this past winter in one storm we had 18+" of snow but it was a very unusually tough winter.
I was wondering about the 6x6's as well I think I would feel better with a larger post or maybe even an alternate wall construction method?
   / Poles for Pole Barn Sizing #5
I think of 6x6 as the standard with some using 4x6 on all but the corners. With 16' side walls are you planning on hay storage in a loft?
MarkV
No hay storage as of right now. The current plan is to build the 36x36 structure for a horse barn until we can build our barn/house in the future which will be much nicer and larger.
By using freespan trusses later down the road I can tear the stalls out and finish pouring the floor in concrete and have a very nice/garage/equipment storage/hay barn. Basically whatever we would want to use it for.
Sort of like a temporary fix that will till be very useful later down the road.
Also I had planned on spacing the poles 12' on center, is that to far apart? Perhaps back down to 6' on center?
   / Poles for Pole Barn Sizing #8
I think 6x6's would work fine but I was curious as to why you andted 16' high walls??? Just for horses and then later a garage, wouldn't 10-12' be pleanty??
But just for an example, back on grandpas farm, he had a morton barn built ~20 years ago. It's 40x80 and 16' high walls (combine storage). Posts are 8' OC and are made up of 3 2x6's (which only measures 4.5" x 5.5"), with the trusses setting on top of each post. (sandwitched between the 2 outer 2x6's).
The building has stood for 20 or better years and still looks good. I live in Ohio and we do get some decient snow loads too.
I'd say, if you get 8' OC trusses, then set the posts 8' appart. This will also reduce the size of header board that you need.
   / Poles for Pole Barn Sizing #9
What do local codes call for? Any advice given is only supposition if local codes stipulate differently. Quite an expensive oops if you start a build thats not code approved.
   / Poles for Pole Barn Sizing #10
I have a Cleary polebarn - 42' x 72' x 12' or 13' high walls, built with clear span trusses that uses exactly this type of construction (laminated posts, of three 2 x 6's) - not sure on the roof pitch, but 4:12 sounds about right ..... poles are 8' OC.
Using lam posts is (potentially) stronger than a solid 6 x 6 .....
Be sure when you build the posts to leave the center 2 x 6 shorter on the top than the outside boards, leaving a slot to set the truss in. Set the posts and then cut a short section of 2 x 6 for the center of the post, that the truss will set on, to set the truss at the correct height. Then trim the outside boards to length. :thumbsup:
   / Poles for Pole Barn Sizing #11
Maybe he has a new breed of horse that's really really tall. :D :D
I agree that 16' walls is pretty high for a 36x36. Unless he plans on putting a loft in it.
Wedge
   / Poles for Pole Barn Sizing #12
I am seeing more and more polebarns using the 2x6 sandwiched method for the posts these days. You can't seem to get solid 6x6 posts over ten feet long that at least 20% don't twist like a pretzel.
I figured at 16' high I could stack my round bales three tiers high if I decided to use it for hay storage later. Or when I upgrade my trator I wont ever have to worry about it not fitting through the door, or if I want to put a vehicle lift in and put my one ton truck on it and raise it 6' in the air to walk under I will still have plenty of roof clearance.
I am very interested in the 8' lamintated post construction method, then what does one do? turn the purlins perpindicular to the roof line and run them like beams on 2' centers?
Does someone have pictures?
   / Poles for Pole Barn Sizing #14
Ditto Ditto
And if the width could be changed to 28' it will change the truss structure dramatically. Just add to the length to make up the sq. ft. if need be.
The neighbor kid built his own poles on the Morton design with the trusses on top of the poles. Makes truss installation a snap. Notice the roof purlin clips that were attached by the truss construction company for ease of purlin install.
http://i25.tinypic.com/hsl0dz.jpg[/IM
[IMG]http://i25.tinypic.com/hsl0dz.jpg[/IM
For reasons unknown to me Tinypic isn't cooperating very well.
   / Poles for Pole Barn Sizing #15
6x6's should be fine but you are going to need an adequate footer under them. If it were me I would do a 24" diameter by 10" thick footer for each post.
   / Poles for Pole Barn Sizing #16
I am not sure what you mean about the purlins. They run just the same as any other purlin, parallel with the ridge line, on 2' center (depending on metal), and standing on edge (2x4) if spanning 8'. If you happen to only get 4'OC rated trusses, you will still need a large header board to support the trusses in the middle, but you could lay the purlin down to give more room for error when putting roofing on.
As to the post construction, Obviously the 2x6's in the ground are PT and rated for ground contact. Once above ground, you can use just regular construction 2x6's. That usually makes them cheaper than 6x6's that are PT'ed all the way up.
You may have to do some reading as I am not sure of the measurements of how they stagger the 3 2x6's, or how many nails they use etc.
   / Poles for Pole Barn Sizing #17
I purchased the book "Pole Building Projects" by Monte Burch at my local Tractor Supply that has all the information you will require in the book.:thumbsup:
   / Poles for Pole Barn Sizing #18
Have a peek here at page no. 3 of my thread - construction pics should start near the bottom of the page:
New Driveway & Polebarn
   / Poles for Pole Barn Sizing #19
Looks like you missed the ending G] of the [/IMG] tag.
Aaron Z
   / Poles for Pole Barn Sizing #20
Thanks a bunch for correcting my non computer skills mistake Aaron Z.
And for some reason I got the same pic copied twice when there should have been a second pic.
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
Case Titan 3530 (A61307)
Case Titan 3530...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2018 Chevy Traverse 3rd Row Seating (A61306)
2018 Chevy...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
