HST clutch purpose
   / HST clutch purpose #1
TonyF
Huntsville AL
BX200D w/FEL, B21 TLB, KX91-3SS. F700 Dump Truck
Why a clutch on a hydrostatic trans? I have an older BX with HST and no clutch, and a newly acquired B21 with HST with a clutch, whats the real purpose or usefulness behind the clutch on an HST, besides the obvious?
thanks,
   / HST clutch purpose #2
I believe the clutch is necessary to change gears. The BX only has one gear.
   / HST clutch purpose #3
thanks,
The B needs the clutch for the PTO also
   / HST clutch purpose #4
Look and feel. When people by a "real" tractor, they want a clutch pedal. There are several smaller tractor models that really do not need a clutch on them.
   / HST clutch purpose #6
If all else fails ... push in the clutch! (and hit the brakes)
   / HST clutch purpose #7
thanks,
I honestly don't know, but that is the only thing I don't like about my L5030 and the only thing I consistently use it for is to start.
   / HST clutch purpose #8
I use the clutch to pick up the load on a PTO implement. The hydro clutch is pretty abrupt, and can put a lot of strain on the drive line and gears. I also use it as an emergency disconnect when I get into a situation I didn't anticipate. My HST pedal is perfectly centered, so I don't have to use a clutch to change gears, but not all HST pedals are that well adjusted.
The clutch also disconnects the wobble pump, and makes starting easier. The hydraulic pumps stay live, though.
   / HST clutch purpose #9
My Kubota B7800 has a hydrostatic transmission but also has a clutch. This is needed to engage (or disengage) either the mid or rear pto.
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2017 Kubota M5-111D 105HP Agricultural Tractor (A52377)
2017 Kubota...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
