HST clutch purpose
   / HST clutch purpose #1
TonyF
Huntsville AL
BX200D w/FEL, B21 TLB, KX91-3SS. F700 Dump Truck
Why a clutch on a hydrostatic trans? I have an older BX with HST and no clutch, and a newly acquired B21 with HST with a clutch, whats the real purpose or usefulness behind the clutch on an HST, besides the obvious?
thanks,
   / HST clutch purpose #2
I believe the clutch is necessary to change gears. The BX only has one gear.
   / HST clutch purpose #3
thanks,
The B needs the clutch for the PTO also
   / HST clutch purpose #4
Look and feel. When people by a "real" tractor, they want a clutch pedal. There are several smaller tractor models that really do not need a clutch on them.
   / HST clutch purpose #6
If all else fails ... push in the clutch! (and hit the brakes)
   / HST clutch purpose #7
thanks,
I honestly don't know, but that is the only thing I don't like about my L5030 and the only thing I consistently use it for is to start.
   / HST clutch purpose #8
I use the clutch to pick up the load on a PTO implement. The hydro clutch is pretty abrupt, and can put a lot of strain on the drive line and gears. I also use it as an emergency disconnect when I get into a situation I didn't anticipate. My HST pedal is perfectly centered, so I don't have to use a clutch to change gears, but not all HST pedals are that well adjusted.
The clutch also disconnects the wobble pump, and makes starting easier. The hydraulic pumps stay live, though.
   / HST clutch purpose #9
My Kubota B7800 has a hydrostatic transmission but also has a clutch. This is needed to engage (or disengage) either the mid or rear pto.
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
24008 (A53422)
24008 (A53422)
