how often do you service your tractor?
   / how often do you service your tractor? #21
Engine oil and filters at 200-250hrs and rear end filters every 1000hrs or so .
   / how often do you service your tractor? #22
I'd always cahnge the filter when i did the oil.. and in your case, I'd do the tranny fluid every 2ys or 1200 hrs.. whatever came first.
soundguy
   / how often do you service your tractor? #23
Like Roy :), I had never changed my coolant in seven years and 1075 hours. My bad, but it always looked clean and my tractor is kept in a garage that stays above freezing all winter. The recommended interval is three years.
That was on today's to do list. When I flushed the radiator and block with the engine running and hose stuck in the radiator cap hole per the instructions in the manual, not a speck of sediment, nor a drop of rusty water to be seen. The water was shooting out the engine block drain in a nice even, strong, clear stream.
I was thinking antifreeze and metallurgy have come a long ways since the 1960's. :)
Dave.
   / how often do you service your tractor? #24
does that tc 40 need the fw15 addative?
soundguy
   / how often do you service your tractor? #25
soundguy
That's something I want to check on more after reading the 'Which Antifreeze' thread. The manual just says 50-50 mix of distilled water and 'permanent antifreeze'. I bought the pre-mixed Prestone extended life stuff to avoid putting our well water in it. My guess is that if something special were needed, NH would have their own branded antifreeze and specify that.
The manual doesn't decribe the cylinder type, sleeved or parent bore, which I guess is what makes a difference for cavitation issues?
Dave.
   / how often do you service your tractor? #26
My guess is that if something special were needed, NH would have their own branded antifreeze and specify that..
uh.. well.. they kinda DO.. they sell the FW15 addative....
soundguy
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
Auger Skid Steer Attachment with Bits (A59228)
Auger Skid Steer...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
